Trackers
Trackers
Forum Topic - Interruption: (4 Items)
Interruption
I'm trying to use the interruption and I would liko to know how do it using the edge. That's my code:
struct sigevent event;
void* int_thread (void *arg);
const struct sigevent * isr_handler (void *arg, int id);
int var=0;
    event.sigev_notify = SIGEV_INTR;
    while(1){
        pthread_create (NULL, NULL, int_thread, NULL);
        delay(1000);
const struct sigevent * isr_handler (void *arg, int id) {
    var ++;
    return (&event);
  int errvalue, erroWait, valor;
  ThreadCtl (_NTO_TCTL_IO, NULL); // enable I/O privilege
  InterruptAttach(0xE,isr_handler,NULL,0,_NTO_INTR_FLAGS_TRK_MSK);
  //InterruptAttachEvent(0xE,&event,_NTO_INTR_FLAGS_TRK_MSK);
  //errvalue = errno;
  //printf("Erro: %s\n", strerror(errvalue));
  while (1)
        InterruptWait (NULL, NULL);
        erroWait=errno;
        printf("erroWait=%s %d\n", strerror(erroWait),var);
I'm doing the interruption on IRQ15, but when I run this code, it interrupts alone, without doing anything.
Thanks.
(Sorry about my english.)
RE: Interruption
> From: Diogo Dias [mailto:community-noreply@qnx.com]
> Sent: February-17-09 11:50 AM
> To: momentics-community
> Subject: Interruption
> int var=0;
Use SIGEV_INTR_INIT( &event ) instead, although what you did is ok.
>     while(1){
// Check the return value
>         delay(1000);
This will create a thread every second, is that intended?
>     var ++;
>     return (&event);
>   //errvalue = errno;
>   while (1)
>         erroWait=errno;
Are you sure the hardware interrupt is generated?
> Thanks.
> http://community.qnx.com/sf/go/post22359
Re: RE: Interruption
Yes, I'm sure. Returns it:
erroWait=No error 1
erroWait=No error 7
erroWait=No error 8
erroWait=No error 9
erroWait=No error 10
erroWait=No error 13
erroWait=No error 14
erroWait=No error 15
erroWait=No error 16
erroWait=No error 17
erroWait=No error 18
erroWait=No error 19
erroWait=No error 20
erroWait=No error 21
erroWait=No error 22
erroWait=No error 23
erroWait=No error 25
erroWait=No error 27
erroWait=No error 29
erroWait=No error 33
erroWait=No error 37
The number is the "var"
That means it's interrupting, isn't?
______________________________________________________
And about the edge? How can I use the interruption by edge?
RE: RE: Interruption
> Sent: February-17-09 1:00 PM
> Subject: Re: RE: Interruption
> erroWait=No error 1
> erroWait=No error 7
> erroWait=No error 8
> erroWait=No error 9
Seems like it.  Note that errno is only valid if InterruptWait returns -1.  What I mean is that errno is NOT set to EOK
when there are no error, you code could well show an error code when there isn't any error
	if( InterruptWait (NULL, NULL) == -1 )
		erroWait=errno;
      	printf("erroWait=%s ", strerror(erroWait));
	printf("Val %d\n", val );
The fact that you have strange value for "var" is probably because there are more than one instance of the interrupt
thread.
That depends on the hardware. On PCI all interrupts are level, on ISA they are edge.  As far as I know there is nothing
you can do about that.
> http://community.qnx.com/sf/go/post22368
