Forum Topic - phrelay issue: (3 Items)
phrelay issue
My x86 6.4.0 target is exhibiting a strange problem.  It's a custom make image which when it was build on 6.3.2 was
running fine.
When the machine boots it start an io-display less version of Photon. That session is only visible with phditto/phindows
 as it's not attached to any graphic driver. That works fine.
The problem is when we try to use phindows to create a new photon session.  Phindows closes right after login in . I've
added debug option to phrelay trying to figure out who's not a happy camper.  Only meaningfull message I could find was:
 io-display is not running, unable to continue.
I have no idea why phrelay would expect io-display to be there. Any idea?
RE: phrelay issue
The general sequence phrelay uses to start its own photon session is:
1) Creates a /dev/ph$$ name where $$ comes from getpid()
2) Starts /usr/photon/bin/Photon with this name, and uses the -l option
to make the photon server run phlogin.
3) When phlogin successfully validate's the user's password, it runs the
/usr/bin/ph script.
4) Phrelay then runs ph.setup and PhAttach's to /dev/ph$$
It looks like you have found a bug in the ph script. It checks to make
sure that io-display is  running, but if io-graphics does not need to be
started this check should not be made.
My suggested fix is to edit the /usr/bin/ph script and put the following
if statement around the /dev/io-display check:
if phin -TG -q 2>/dev/null ; then
    </dev/io-display check>
fi
I have created PR65352 to track this problem.
Sent: Monday, February 09, 2009 8:24 PM
To: momentics-community
Subject: phrelay issue
image which when it was build on 6.3.2 was running fine.
That session is only visible with phditto/phindows as it's not attached
session.  Phindows closes right after login in . I've added debug option
meaningfull message I could find was: io-display is not running, unable
to continue.
idea?
http://community.qnx.com/sf/go/post21851
RE: phrelay issue
That did it thanks!
> From: Max Feil [mailto:community-noreply@qnx.com]
> Sent: February-10-09 5:48 PM
> Subject: RE: phrelay issue
> the
> /usr/bin/ph script.
> be
> following
> fi
> make
> option
> to continue.
> idea?
> http://community.qnx.com/sf/go/post21939
