TFTP Problem , System Builder Binary Selection Problem
12/12/2008 7:37 AM
post18483
Hi Guys,
I'm using Momentics 4.5.0 Build id: I20080926.
I have some problem with the builtin TFTP server:
I have setup my environment/perspective so TFTP is open when starting momentics. The problem is that when booting my
target, TFTP won't come up right away.. UBoot reports timeouts... only when i click the TFTP Tab, it seems to become
active and the board then successfully loads via TFTP.
Will this be fixed in later versions?
Another Problem is that in this version, when I try to add bianries to include with the IFS image in the system builder
project, the automatic "narrowing" of the binaries does not work properly. In older versions, typing "q" in the filename
field would narrow the selection down to "qconn, qcp, qed, qtalk" (for example). In this version, the dialog reports "
File cannot be found" until you fully type e.g. "qconn", and there's no automatic narrowing of the scope as you type
along.
Greetings,
Marc
