Forum Topic - crt1.o: (16 Items)
crt1.o
Hello
I developp an application, and when I want to compil it, i have this message :
/usr/bin/ntox86-ld: cannot open /x86/lib/crt1.o: No such file or directory
This file don't exists in this directory.
I don't understand why I have this problem ; I have many times compile programs without this error.
Is is a PATH problem ?
Thank's
Nicolas PIEQUET
Re: crt1.o
Nicolas PIEQUET wrote:
> Hello
Check to make sure your $QNX_TARGET environment variable is set.
Ryan Mansfield
Re: crt1.o
cat $QNX_TARGET
Nothing ...
Re: crt1.o
sorry ...
echo $QNX_TARGET .. Nothing...
RE: crt1.o
You can`t cat an environment variable, you have to use echo or print
> From: Nicolas PIEQUET [mailto:community-noreply@qnx.com]
> Sent: December-10-08 7:54 AM
> To: momentics-community
> Subject: Re: crt1.o
> cat $QNX_TARGET
> Nothing ...
> http://community.qnx.com/sf/go/post18274
Re: crt1.o
What have I to do ?
Re: crt1.o
> What have I to do ?
Set it to where you've installed your QNX directory. For example the
default windows install happens at:
C:/QNX6xx/
QNX_HOST should be set to:
C:/QNX6xx/host/win32/x86/
QNX_TARGET should be set to:
C:/QNX6xx/target/qnx6
Ryan Mansfield
Re: crt1.o
I'm on QNX host ...
The file is not in /x68/lib, but in /pkgs/repository/qnx/os/dev_x86-2.1.3/x86/lib .
This directory must be in the PATH ?
Why I suddenly have this problem ?
Re: crt1.o
> I'm on QNX host ...
Because your QNX_TARGET is not set. You look like you have a nonstandard
install.
Type:
export QNX_TARGET=/pkgs/repository/qnx/os/dev_x86-2.1.3/
Ryan Mansfield
Re: crt1.o
That looks like a 6.2.1 pkg installation?  Are you running 6.2.1?
>> I'm on QNX host ...
> install.
> Type:
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post18284
cburgess@qnx.com
Re: crt1.o
Er, yes it does. Sorry, I was assuming it was a 6.3.x or newer install.
Nevermind my comments about the env variables.
Under 6.2.1, I believe the target directory at the root (/x86/...) so
crt1.o should be pulled from under /x86/lib/ and not the packaging
directory.  Does /x86/lib/crt1.o still exist and does it have the proper
permissions?
Ryan Mansfield
Re: crt1.o
I think it sounds like the package is not installed correctly?
> permissions?
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post18289
cburgess@qnx.com
Re: crt1.o
Sounds like something after the installation because Nicolas did say he
was able to compile at one point.
Ryan Mansfield
Re: crt1.o
"Nicolas did say he was able to compile at one point."
    Yes, I was.
    I don't know why I'v this problem now ...
I'm working with QNX 6.2.1A
Re: crt1.o
I understand!
Sorry for the annoyance ...
I ran a script of "clean" in the wrong directory ...
"rm *. o":-s:-s
It is probably not a good idea to develop with both the "root" ...
Thank you anyway for your help
Nicolas PIEQUET
Re: crt1.o
It's ok, you've just learned the hard way that root should not be your regular
userid. :-)
Colin
> I understand!
> "rm *. o":-s:-s
> Nicolas PIEQUET
> http://community.qnx.com/sf/go/post18309
cburgess@qnx.com
