Forum Topic - XML on QNX: (9 Items)
XML on QNX
Is there any libery to extract easily the datas of a xml document ?
I want to transfert datas through UDP datagrams, and use XML format into this datagrams.
Thank's
AW: XML on QNX
in usr/lib you'll find libexpat
as far as I know there's no header around for this lib, so you'll have to setup your own.
for more information on expat go to http://expat.sourceforge.net
/hp
>Von: Nicolas PIEQUET [mailto:community-noreply@qnx.com]
>Gesendet: Mittwoch, 19. November 2008 08:20
>An: momentics-community
>Betreff: XML on QNX
>Hello,
>Thank's
>QNX Momentics Community Support
>http://community.qnx.com/sf/go/post16848
Management Board: Dr. Klaus Blickle (Chairman), Dr. Udo Hüls, Michael Mauser, Regis Baudot
Re: AW: XML on QNX
what do you mean by "you'll have to setup your own" ?
AW: AW: XML on QNX
as there is no c header file that defines the function prototypes and structres
you need this definitions that you can use the library.
and so you'll have to setup a the definitions in a header you can use in your source.
/hp
>Gesendet: Mittwoch, 19. November 2008 09:56
>Betreff: Re: AW: XML on QNX
>http://community.qnx.com/sf/go/post16853
Re: AW: XML on QNX
Is it possible to write XML files with Expat ?
RE: AW: XML on QNX
No.
From: Nicolas PIEQUET [mailto:community-noreply@qnx.com]
Sent: November 19, 2008 8:51 AM
To: momentics-community
Subject: Re: AW: XML on QNX
http://community.qnx.com/sf/go/post16872
RE: XML on QNX
If you don't mind C++ take a look at the Poco Library ( google it)
Sent: November 19, 2008 2:20 AM
Subject: XML on QNX
Thank's
Re: RE: XML on QNX
There is a lot of thinks here ... Thanks
Can I use this  libraries with C programs or only C++ ?
RE: RE: XML on QNX
If you are talking about Poco, it`s C++ only, but your program can be mostly C and you just provide C++ cover function.
Sent: November 19, 2008 9:05 AM
Subject: Re: RE: XML on QNX
http://community.qnx.com/sf/go/post16876
