Forum Topic - trouble installing Neutrino on pc104: (9 Items)
I'm having problems installing qnx 6.3.2 and/or qnx 6.4.0 using Qnx Neutrino Lite cd-rom on an Eurotech cpu1452 ( pc 104
 with celeron ).
I tried installing it on different IDE disks but the install process aborts always when the copy of system files to disk
 starts.
I also tried making a disk with system image but it seems unable to mount succesfully the disk.
With other OSs (Ubunt for ex.) the "standard" install process ended succesfully.
Any idea of what is the problem and how can I resolve it?
RE: trouble installing Neutrino on pc104
Hi Michele,
When you boot the CD you have the option of running from the CD. Does
this work? If it does it would help to get the output of "sloginfo" and
"pci -vv".
You can enable verbosity in the installation by hitting F1 at the start
of the installer. This may help pinpoint the problem.
Also can you post exactly what is on the screen upon failure?
Keith Russell
From: Michele Cesaro [mailto:community-noreply@qnx.com]
Sent: November 5, 2008 05:27
To: momentics-community
Subject: trouble installing Neutrino on pc104
Neutrino Lite cd-rom on an Eurotech cpu1452 ( pc 104 with celeron ).
aborts always when the copy of system files to disk starts.
succesfully.
http://community.qnx.com/sf/go/post15953
Re: RE: trouble installing Neutrino on pc104
thank you for replying, here is the output of install procedure when it crashes:
>Executing /proc/boot/mkqnx6fs -q -T desktop /dev/hd0t179
>Copying files to the new QNX partition. Please wait...
>cp: read (/qnxbase/boot/sys/startup-bios): Input/output error
>/proc/boot/cp: failed (405515 256)
I wasn't also able to run Qnx from cd, this is the error message I get:
>could not load library libz.so.2
>Starting extra run commands
>/etc/system/sysinit: /etc/rc.d/rc.sysinit[59]: -p: cannot execute -No such file or directory
regards,
Michele
I also attach "lspci -v" output obtained on the pc104 running Ubuntu:
0000:00:02.0 VGA compatible controller: Intel Corporation 82815 CGC [Chipset Graphics Controller] (rev 04) (prog-if 00
[VGA])        Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 9
        Memory at 7c000000 (32-bit, prefetchable) [size=64M]
        Memory at 80100000 (32-bit, non-prefetchable) [size=512K]
        Capabilities: [dc] Power Management version 2
0000:00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 05) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
        I/O behind bridge: 0000f000-0000ffff
        Memory behind bridge: 80000000-800fffff
0000:00:1f.0 ISA bridge: Intel Corporation 82801BA ISA Bridge (LPC) (rev 05)
        Flags: bus master, medium devsel, latency 0
0000:00:1f.1 IDE interface: Intel Corporation 82801BA IDE U100 (rev 05) (prog-if 80 [Master])
        I/O ports at ec00 [size=16]
0000:00:1f.2 USB Controller: Intel Corporation 82801BA/BAM USB (Hub #1) (rev 05) (prog-if 00 [UHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 9
        I/O ports at e800 [size=32]
0000:00:1f.3 SMBus: Intel Corporation 82801BA/BAM SMBus (rev 05)
        Flags: medium devsel
        I/O ports at 70c0 [size=16]
0000:00:1f.4 USB Controller: Intel Corporation 82801BA/BAM USB (Hub #2) (rev 05) (prog-if 00 [UHCI])
        I/O ports at e400 [size=32]
0000:01:04.0 USB Controller: Philips Semiconductors USB 1.1 Host Controller (rev 11) (prog-if 10 [OHCI])
        Subsystem: Philips Semiconductors USB 1.1 Host Controller
        Flags: bus master, medium devsel, latency 32, IRQ 9
        Memory at 80000000 (32-bit, non-prefetchable) [size=4K]
0000:01:04.1 USB Controller: Philips Semiconductors USB 1.1 Host Controller (rev 11) (prog-if 10 [OHCI])
        Memory at 80001000 (32-bit, non-prefetchable) [size=4K]
0000:01:04.2 USB Controller: Philips Semiconductors USB 2.0 Host Controller (rev 11) (prog-if 20 [EHCI])
        Subsystem: Philips Semiconductors USB 2.0 Host Controller
        Memory at 80002000 (32-bit, non-prefetchable) [size=256]
0000:01:06.0 Bridge: Integrated Technology Express, Inc. IT8888F PCI to ISA Bridge with SMB (rev 03)
0000:01:08.0 Ethernet controller: Intel Corporation 82801BA/BAM/CA/CAM Ethernet Controller (rev 03)
        Subsystem: Intel Corporation EtherExpress PRO/100 VE
        Memory at 80003000 (32-bit, non-prefetchable) [size=4K]
        I/O ports at fc00 [size=64]
regards
Michele
RE: RE: trouble installing Neutrino on pc104
That sounds like your CD is bad.
Can you verify the cksum of the ISO against the download center? If that
matches you can verify the burn by comparing against the ISO. If I
remember correctly on Linux if you put the CD in the drive then you can
run 'cmp <iso> <drive>'. If it ends with an EOF they match. I may have
the order of the arguments wrong...
Keith Russell
Sent: November 6, 2008 05:49
Subject: Re: RE: trouble installing Neutrino on pc104
[Chipset Graphics Controller] (rev 04) (prog-if 00 [VGA])        Flags:
05)
regards
Michele
http://community.qnx.com/sf/go/post16053
'cmp' command ends reaching EOF, notice that I had the same problem also with qnx 6.3.2 on this pc104, maybe some
hardware incompatibilities?
Michele
It is possible you are having trouble with DMA. When the system starts
you can try disabling it by hitting 'D' at the start of the boot when
the message instructs you to hit space or D.
Keith Russell
Sent: November 6, 2008 09:45
Subject: RE: trouble installing Neutrino on pc104
with qnx 6.3.2 on this pc104, maybe some hardware incompatibilities?
Michele
http://community.qnx.com/sf/go/post16090
I've tried this option but install process ends again with "Partition installation aborted!" message. I've got the same
result trying the F10 option (forced mount or something like this..). I'm starting to think that there are some problems
 between devb-eide and Intel 815E chipset, maybe?
Michele
> Keith Russell
I've pinged the hardware folks to see if they know of any issues.
Keith Russell
Sent: November 17, 2008 06:07
installation aborted!" message. I've got the same result trying the F10
that there are some problems between devb-eide and Intel 815E chipset,
maybe?
Michele
> Keith Russell
http://community.qnx.com/sf/go/post16635
