Forum Topic - R_386_NONE relocations and "Unknown Symbol" errors: (8 Items)
Hello everyone,
I'm working on a modular C++ program which loads its components via dlopen(). We've recently run into an issue and we
don't really know where to go from here, unfortunately.
Point #1: We can't use GCC 2.95 because of a compiler issue (it does not handle something in the language per standard).
 We can work around this issue, but the workaround is to make all members of one of our classes public, which we believe
 is not a real solution.
Point #2: We have GCC 3.3.5 (and recently 4.2.3) but both of them are giving us issues at runtime.
Everything goes smoothly until we reach dlopen() and try to open our shared object file. At this point, we see this:
unknown symbol:
unknown symbol:
unknown symbol:
unknown symbol:
unknown symbol:
sercom_g.so is an invalid module: Unresolved symbols
(Note that the last line is actually output by the application calling dlopen() as it detects the failure and then
outputs the return from dlerror()).
After a lot of research last night, we came across this linker issue between 2.95 and 3.3.5 resulting in R_386_NONE
relocations. Now in all honesty, I have no idea what that actually means, but everything I read makes it sound bad. Sure
 enough:
bash-2.05a# ntox86-readelf -r ./sercom_g.so | grep R_386_NONE
00000000 00000000 R_386_NONE
These go away when we use our workaround and compile for 2.95. We have rechecked the compiler tools to ensure that all
components are being compiled with 3.3.5 (and then later 4.2.3) several times, and have gone as far as reinstalling QNX
on the target and trying all over, but we still see the same result.
Does anyone have any suggestions on how to proceed? I don't see any reason why it should be loading in the libraries
from 2.95, however I noticed the following earlier (I read that libcpp.so.3 is for 2.95-compiled applications, thus
should not be here:)
bash-2.05a# export DL_DEBUG=1
bash-2.05a# ./base_g
load_object: attempt load of libcpp.so.3
load_elf32: loaded lib at addr b8200000(text) b825d640(data)
dlopen("/root/sec09/modules/sercom_g.so",0)
load_object: attempt load of /root/sec09/modules/sercom_g.so
load_elf32: found DT_TEXTREL, mapping a private copy of text sections!
load_elf32: loaded lib at addr b8274000(text) b82ac860(data)
dlsym(8063330,_btext)=804fa74
Library loaded; type 'add-sym sercom_g.so 804fa74' in gdb to load symbols
load_object: attempt load of libcpp.so.4
load_elf32: loaded lib at addr b82b2000(text) b83010e0(data)
unknown symbol:
unknown symbol:
unknown symbol:
unknown symbol:
unknown symbol:
As you can see both libcpp.so.3 and libcpp.so.4 are showing up. This doesn't seem correct to me.
Any suggestions would be greatly appreciated, because as it stands right now we don't know how to proceed.
-- Matthew P. Del Buono
Re: R_386_NONE relocations and "Unknown Symbol" errors
Use either -Wl,-t or -W,--verbose to see how libcpp.so.3 gets linked in.
  If you are compiling everything with 3.3.5, libcpp.so.3 should
definitely not be there, and it will cause serious problems.
First, resolve the issue of linking in libcpp.so.3 and then check to
make sure you are not linking in non-PIC code into your shared object.
Ryan Mansfield
This looks like a mix of 2.95.3 and 3.3.5 objects.  The base executable loads libcpp.so.3,
and the load of the dll loads libcpp.so.4
You can't safely mix C++ objects that were compiled with different versions of the compiler.
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post12533
cburgess@qnx.com
>  the compiler.
I'm aware of that. Unfortunately, I don't see why there would be different versions. In Momentics, as far as I can see,
all of them have the same version of the compiler selected.
I have installed now 4.2.1 and binutils 2.17 to try once more.  I then ran this line off a suggestion from another post
to replace all of the base things with the 2.17 versions in hopes that this might be a problem, but I have had no effect
bash-2.05a# for file in `ls ntox86-*-2.17`; do cp -f $file `echo $file | sed 's/ntox86\-\([^-]*\)\-2.17/i386-pc-nto-qnx6
.3.0-\1/g'`; done
I should explain my project, probably. I have 4 components right now: The main application (called base), a module
(called sercom), and two static libraries (called util and serlib).
serlib is linked into sercom, and util is linked into base, sercom, and serlib. (Hint: Is it possible that the fact that
 util links into serlib and then into sercom is a problem?).
Anyway, attached is the output from adding -Wl,-t as you recommended. I don't see any indicaton of using the 2.95 tools,
 etc. Do you? I split them up into 4 text files for easier viewing.
One thing I DID notice is that "util" and "serlib" did not seem to be listening to the -Wl,-t option; I don't see it
used at all in the command lines. I put it under the "linker" options in momentics for the projects -- is this correct?
I thought it was, but I don't see it used anywhere.
Attachment: Text base.txt 3.65 KB
This is the output from sercom's build (Sorry for all the posts, but I can only attach one file at a time)
Attachment: Text sercom.txt 4.68 KB
This is the output from serlib's build. Note that -Wl,-t does not show up anywhere in the build.
Attachment: Text serlib.txt 3.28 KB
This is the output from util's build. Again, note the lack of -t being passed to the linker.
Attachment: Text util.txt 2.15 KB
Sorry for the sudden spam of posts. I seem to have found an (if not /the/) issue. As I mentioned earlier, I found it
quite strange that "serlib" and "util" were not listening to my linker settings.
I changed "serlib" and "util" to be "shared library without export" instead. After the appropriate modifications to the
projects to account for this change, I am very happy to say that everything seems to be working OK.
This does, however, bring up an issue: I am perfectly OK with using this form instead of a static library, but why
exactly can't I use a static library? This seems out of whack to me.
Anyway, thanks for the prodding in the right direction. Hopefully this will be the end of this little nightmare (with
many more to come :D)
