Forum Topic - return of incompatible reference does not trough an error on qcc: (2 Items)
Hi ,
The following sample program does not trough either compiler or linker error when compiled using qcc.
$ qcc test.cc
But, when I try to compile it with gcc it troughs the following error
test.cc: In function `int main()':
test.cc:11: error: invalid initialization of non-const reference of type 'unsign
ed int&' from a temporary of type 'unsigned int'
test.cc:3: error: in passing argument 1 of `void testa(unsigned int&)'
Somebody please tell me why the qcc is not detecting the incompatible reference type, ofcourse the output file fails to
return the expected value at runtime..
void testa(unsigned int &x)
x=20;
main(void)
unsigned int a;
unsigned long b;
unsigned char ptr= 'a';
testa((unsigned int) b);
Thanks in Advance
Warm regards
Annam K
Re: return of incompatible reference does not trough an error on qcc
Annam Krupakar wrote:
> Hi ,
> $ qcc test.cc
to return the expected value at runtime..
qcc is just a compiler driver. By default, when you invoke qcc t.cc it
uses gcc 2.95, and you are comparing it to a newer version of gcc.
Earlier versions of gcc (pre-gcc 3.4) were very permissive with respect
to C++ and did not catch this error.
You can download gcc 4.2 from the core developments project on the
foundry and then change the default compiler qcc uses.
Ryan Mansfield
