08/04/2008 10:10 AM
post11399
In my software a call to resmgr_attach() is failing with a -1 returned. I'm assuming it's because the IDE is not
running the program on the target as root. The documentation says running as root is the default but that does not seem
to be the case. If I run it from the command line on the target it runs OK.
Any help will be appreciated.
Bob
