Re: How to start remote application
05/17/2009 3:37 PM
post29601
Hi all,
Is there anyone who has encountered this error, and get it solved? I'm having the same problem.
I am using QNX Momentics on a Linux machine (running Ubuntu 8.10), and I successfully cross-compile my software to
remote QNX6.3.2 machine(installed on a Lippert board) from the Linux machine. I have no problem in running the QNX
driver remotely, but when I try to run the application (which is a client of the QNX driver), it fails with the similar
error below. Has anyone got any ideas?
Error starting remote application.
com.qnx.tools.utils.target.QConnException: Target launcher@<localhost:8000>: Error Can't access shared library
at com.qnx.tools.utils.target.TargetBinary.parseResponse(TargetBinary.java:130)
at com.qnx.tools.utils.target.TargetServiceLaunch.launch(TargetServiceLaunch.java:136)
at com.qnx.tools.utils.target.TargetProcess.startProcess(TargetProcess.java:46)
at com.qnx.tools.utils.target.TargetProcess.<init>(TargetProcess.java:15)
at com.qnx.tools.ide.qde.internal.ui.launch.QDELaunchUtils.remoteLaunch(QDELaunchUtils.java:236)
at com.qnx.tools.ide.qde.internal.ui.launch.QDELaunchConfigurationDelegate.
startApplicationOnTarget(QDELaunchConfigurationDelegate.java:579)
at com.qnx.tools.ide.qde.internal.ui.launch.QDELaunchConfigurationDelegate$1.doRun(QDELaunchConfigurationDelegate.java:
879)
at com.qnx.tools.ide.qde.internal.ui.launch.QDELaunchConfigurationDelegate$QDELaunchJob.
run(QDELaunchConfigurationDelegate.java:176)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
