Forum Topic - Timer interrupt of the Lite 5200 board: (9 Items)
what is the interrupt vector of the timer interrupt (IRQ 0 on x86) of the Lite5200 board ?
Best Regards
--Armin
Re: Timer interrupt of the Lite 5200 board
> Hello,
> Lite5200 board ?
> Best Regards
> --Armin
normaly You can find this out by doing:
pidin syspage=qtime
You should see something...  .... intr:number
You are searching for number.
-Jeevan
Or, in your code
struct qtime_entry *qtp = SYSPAGE_ENTRY(qtime);
timer_intr = qtp->intr;
Jeevan Mathew wrote:
>> Hello,
>> Lite5200 board ?
>> Best Regards
>> --Armin
> pidin syspage=qtime
> -Jeevan
> http://community.qnx.com/sf/go/post10544
Hi Jeevan,
the code 'works'  ... but it returnes an interrupt vector of 0x80000000.
That seems not to be very useful ?
pidin syspage=qtime seems only to work with QNX 6.3.2 .... I'm testing for the first time under QNX 6.2.
Why is the timer interrupt not documented in the Lite5200B BSP ?
Regards
--Armin
That's the id for the PPC decrementer.
That said, the build file doesn't seem to document those interrupts...
Armin Steinhoff wrote:
> Hi Jeevan,
> Regards
> --Armin
> http://community.qnx.com/sf/go/post10563
Sorry, what is a PPC decrementer ?
Can it be used with a InterruptAttach call ?
--Armin
> > Hi Jeevan,
> > Regards
> > --Armin
The PPC decrementer interrupt is used as the timer interrupt on most PPC
boards.
Yes, you can use it with InterruptAttach();
SYSPAGE_ENTRY(qtime)->intr will always be a useable interrupt id, or
your system will be really hosed.. :-)
Colin
> --Armin
>>> Hi Jeevan,
>>> Regards
>>> --Armin
> http://community.qnx.com/sf/go/post10566
In addition to Colin.
Not that I am a ppc,  despite a ppc-expert, but :-)
Please check this:
http://www.go-ecs.com/ppc/ppctek1.htm#DTB
Jeevan
> boards.
> Colin
> > --Armin
> >>> Hi Jeevan,
> >>> Regards
> >>> --Armin
   ... but it works =:-/   .... any comments ?
--Armin
