Forum Topic - Memory Analysis Tool Can't "see" Source Code: (10 Items)
I'm using the Memory Analysis tool and it shows me errors but no matter what I do I can't get the trace details to show
me the function backtrace by function name.  It only shows me something like this:
0[0xb8207fb7]<no source code>
I've done everything I can think of to get it to show me where in the source code but with no luck.  The debugger can
see the source code at the corresponding address but not the analysis tool.
Any help will be greatly appreciated.
Re: Memory Analysis Tool Can't "see" Source Code
What is the code base c/c++?
What is compiler version?
What is the target architecture?
0xb8 looks like shared library code
is it only one backtrace element shown?
what version of IDE are you using?
show me the function backtrace by function name.  It only shows me something like this:
> http://community.qnx.com/sf/go/post9667
 I'm not sure what you mean by code base.
The compiler is 2.95.3
Target architecture is x86
The 0xb8 was only for example purposes.  In the list of addresses in the traceback it eventually gets up into my code.
I verified this by checking the addresses in the traceback to the addresses listed with function calls in the debugger.
IDE Version: 4.0.1
Thanks!
Bob
Code base I mean C only or C++?
do you use shared libraries?
What project you are using QNX C or Managed C?
Are you actually getting traceback or size more than 1?
Basically IDE find source code based on addresses using the following
things:
- code compiled with -g
- shared libraries path defined for launch config
- binary parser (which has to be enabled for you project if you using
managed projects)
> IDE Version: 4.0.1
> Thanks!
> Bob
> http://community.qnx.com/sf/go/post9676
C++
No shared libraries.  Part of what I'm debgging is a static library.  The other half is a test program to test the port
of this static library.
I'm using a Standard C++ project.
I'm getting tracebacks of upto 16 depending on which error I'm looking at.
1) go to project properties, find Binary Parsers and enable QNX Binary
parser if it not enabled
2) if you process runs less than 1 second it may not work, add 1 second
sleep in the begging of main
Robert Davis wrote:
> C++
port of this static library.
> http://community.qnx.com/sf/go/post9679
Binary parser was already enabled.  I added a sleep but it made no difference.
Check your addr2line utility, if should be in the path and you run it
with -e <your-binary> if should not fail
> Thanks
> http://community.qnx.com/sf/go/post9710
Elena,
Thanks for all your help.  I'm not quite clear about when/where/how to run addr2line.  Should I run it stand alone or
does it run in conjunction with the memory analysis tool?  And where do I specify its path?  Does it go in the C/C++
Project Path in Project Properties?  If so, which tab?
Bob
addr2line is command line tool, IDE uses it to resolve the address to
line-number mapping. To perform the test you just run it from command
line, not from IDE
run bash or cmd (on windows) and type command
addr2line -e <path-to-your-executable>
Btw does you application runs less than 1 second?
Robert Davis wrote:
> Elena,
> Thanks,
> Bob
> http://community.qnx.com/sf/go/post9851
