Forum Topic - RE: shutdown utility -- source code: (4 Items)
I am using a remote login to a machine with no monitor, so when I give it a shutdown command, I'd like to know when
everything is done.  I would like some audible feedback in the shutdown process (hopefully very close to coinciding with
 the 'it is now safe to turn off your computer' screen).  As I have not discovered any shutdown script procedures
similar to startup procedures, I think i may have to build a custom shutdown binary.  Is the QNX6 shutdown the same as
QNX4 shutdown?  If so, I could probably just compile the code from a related post:
http://community.qnx.com/sf/discussion/do/listPosts/projects.community/discussion.qnx4_community_support.topc2364
If not, can someone provide me with the source for QNX632 shutdown?  Or, alternate ideas...
Arthur
Re: shutdown utility -- source code
On Tue, May 27, 2008 at 10:52:06AM -0400, Arthur McClung wrote:
The HEAD shutdown utility has been published in the
coreos project on the foundry (see the source code
section).
Ok, I have two versions of shutdown source folder now (one for photon shutdown, I believe and one for text based
shutdown).  Can someone give me a quick description of how to rebuild this command?  I tried a basic 'make', but
obviously its not that easy. Not sure if I need to be in IDE or command line (gcc, make, ??). Sorry for this silly
question, but I havent configured a build in a while.  Thanks, Arthur
Nevermind, i think.  I believe I figured out what I was doing wrong.
