Forum Topic - How to increase available stack?: (5 Items)
If I request __stackavail() [1] it returns something slightly above 500K (I have qnx 6.3.2)
but ulimit says that stack is unlimited [2]
How can I increase stack size available for alloca?
Thanks a lot!
[1]
#include <alloca.h>
main() {
int n = __stackavail();
printf("avail: %d\n", n);
[2]
bash-2.05a$ ulimit -a
core file size        (blocks, -c) unlimited
data seg size         (kbytes, -d) unlimited
file size             (blocks, -f) unlimited
max locked memory     (kbytes, -l) unlimited
max memory size       (kbytes, -m) unlimited
open files                    (-n) 1000
pipe size          (512 bytes, -p) 10
stack size            (kbytes, -s) unlimited
cpu time             (seconds, -t) unlimited
max user processes            (-u) unlimited
virtual memory        (kbytes, -v) unlimited
Re: How to increase available stack?
> have qnx 6.3.2)
You can give your executable a stack note so the loader gives a larger default stack size with ldrel -S
Ryan Mansfield
it works, thanks a lot!
are there other ways? I have a 3rd party stuff that builds and runs an application. I'm reluctant to modify it, can I
get the same by passing anything to gcc/ld or by changing loader settings?
> default
> application. I'm reluctant to modify it, can I get the same by passing
If you're using qcc, you can use qcc -N which spawns ldrel -S. If you're using the gcc driver, you have to call ldrel
postlink.  I don't think there are any other ways to set the initial default stack size.
If you can't modify the executable to add a stack note at all, one option would be to modify the loader to give all
programs a larger stack size. Look for DEF_VIRTUAL_FIRST_THREAD_STACKSIZE in services/system/proc/loader_elf.c (the
source is available in the OS project).
I'm not endorsing this as a solution but mentioning it in case you're completely stuck. :)
Ryan Mansfield
Thanks, Ryan
