Beagle Bone Black BSP - rebuilt problem
07/11/2016 3:17 AM
post116528
OK after trying hard for a long time I really need help on two problems.
I have a new BBB rev. C and downloaded the BSP for Neutrino 6.6. If I use the prebuilt image, the BBB (doesn't matter if
stable or experimental version) boots as expected. If I try to rebuilt the image (out of the IDE or on command line),
the image does built and the BBB boots up but it says "unable to start..." for all the services.
I looks like during the make process the binaries don't get the executable flag and therefore are not executable when
transferred to the SD Card.
On the other hand I really don't know which build file I have to modify in order to change the image. If I understood
right, I should modify the build file in the src/hardware/startup/boards/ti-am335x/beaglebone/build. But if i uncomment
something in there and rebuilt the image, the resulting build file in the image folder again has this line commented out
Please if someone can help me? Thanks in advance.
