Re: PPS notification group problem
02/26/2016 3:11 PM
post115875
..notify is not for selecting attributes to be notified about, it is as an
alternative for ionotify/poll/select, i.e. as a means of discovering which
of several fds have data available. When you open a pps object using
notify=nnn:mmm the nnn part is for pps to determine which fd it should
notify and mmm is for the client to know which fd it is being notified
about. I don¹t know that there is any reason to use .notify any longer, I
think it is there for purely historical reasons.
If you only want to get the Œid' attribute from a pps object, you¹d open:
/pps/crank/test?f=id
f = filter. I don¹t recall if you can filter more than one attribute.
On 2016-02-26, 2:48 PM, "Brian Edmond" <community-noreply@qnx.com> wrote:
>I have tried using a PPS notification group and they do not seem to work
>as expected. I created the following file:
>/pps/crank/test
>Then use this code:
>#include <stdlib.h>
>#include <stdio.h>
>#include <string.h>
>#include <fcntl.h>
>#include <sys/pps.h>
>int main()
> char noid[16], buf[256];
> int notify_fd, fd1;
> int nread;
> notify_fd = open("/pps/.notify", O_RDONLY);
> read(notify_fd, &noid[0], sizeof(noid));
> noid[strlen(noid)-1] = 0;
> printf("Open Notify fd: <%s>\n", noid);
> sprintf(buf, "/pps/crank/test?notify=%s:id", noid);
> fd1 = open(buf, O_RDONLY);
> printf("Open: %s\n", buf);
> memset(buf, 0, sizeof(buf));
> while((nread=read(notify_fd, &buf, sizeof(buf))) >= 0) {
> if (nread) {
> printf("Notify (%d): %s\n", nread, buf);
> printf("Done: %d\n", nread);
> return 0;
>So a notification group is used to monitor the "id" attribute of the test
>object. Then I write to the object:
> echo "id::1" >> /pps/crank/test
>Now I see the above "Notify" message as I expect.
>Now write to the object again but with a different attribute:
> echo "abc::1" >> /pps/crank/test
>Now I still see the above "Notify" message. However I did not change the
>"id" value so why does read return like I did?
>Thanks,
>Brian
>QNX Momentics Community Support
>http://community.qnx.com/sf/go/post115874
>momentics-community-unsubscribe@community.qnx.com
