select does not unblock when iofunc_notify_trigger invoked from a relatively low priority thread
03/15/2015 3:30 PM
post113554
Observed in QNX 6.5.0 running on in house hardware with EP9301 Cirrus logic SoC.
The problem described here involved two threads ( a Server and Client) with threads as mentioned below
A server with two threads
Thread 1 running resource manger message loop to handle request from client process at priority 11
Thread 2 runs periodically (every 2 seconds) and populates data in a queue and notifies the client by calling
iofunc_notify_trigger()
A client with single thread running at priority 11
This thread runs a loop to read data from server when data is available. This thread blocks on a select call while
waiting for server to produce the data for reading.
Problem:
When the client process is started, the select() returns immediately as long as data is available on server queue and
the client is able to read the data.
When the server queue is empty, the client thread blocks on select().
At this point, the server Thread 2 add data to server queue and notify the client by calling iofunc_notify_trigger().
The client thread gets unblocked and it again blocks on select() after reading the available data.
Now, the next iofunc_notify_trigger() from server Thread 2 does not unblock the client thread from select() and it
continue to wait on SigWaitInfo state.
(NOTE: The call to IOFUNC_NOTIFY_INPUT_CHECK(notifylist,1,0) just before the iofunc_notify_trigger() returned true)
All subsequent check to IOFUNC_NOTIFY_INPUT_CHECK(notifylist,1,0) returns false.
At this point the server is waiting for client to arm using IO_NOTIFY client message and the client it waiting for
server to notify_trigger.
Observations:
1) If I change the server Thread 2 priority to 11 or more then the problem does not occur.
I tried with different priorities for client thread and server Thread 2, it works only when the server Thread 2
priority is greater than or equal to the client thread priority.
2) If I add timeout to select(), the client gets unblocked after timeout and it is able to detect the data
availability on next select call and read the data successfully.
After reading all available accumulated data it goes to blocked state and the problem happens again.
Question:
I could not find any mention about the expected priority for a thread invoking iofunc_notify_trigger (or
MsgDeliverEvent) method in the QNX documentation.
How does the priority of the thread invoking the iofunc_notify_trigger() method cause select to block indefinitely?
If priority is the problem, how does it getting unblocked for the first time?
