JNI Interactions on QNX with SWIG generated source code
11/21/2014 10:29 AM
post112407
Good day,
I'm currently experiencing an issue finding native methods with my JNI jar file and QNX compiled libraries where the
related native methods were generated by SWIG. When I run the JNI jar and make a native method call to the library, I
get an error claiming it couldn't find the method. I know I've loaded the library without error before making the call,
and that the method names for both the Java native methods and the C library methods are correct. I have tested the
libraries and the JNI on Linux and Windows, and had no issues finding the method. I have also created another example
QNX compiled Library and JNI jar that used JNIEXPORT instead of SWIGEXPORT and had no issues there. I was curious if
anyone else has had any issues between SWIG, JNI, and QNX? I'm using Java 5 and QNX 6.4.1. Thank you for your time.
Best Regards,
Andrew
