09/05/2014 2:05 PM
post111665
Not sure what you are attempting to do. Have a look at kill or slay.
From a shell, you can terminate a process using the slay command and the name of the process you are terminating.
You could also kill a process with a SIGTERM or SIGKILL signal.
If you are trying to terminate a process and restart it again within a shell using a single command line, then:
# slay process_name ; process_name
But I may not understand what you are trying to accomplish. Hopefully this is enough to allow you look in the right
location in the documentation.
Dave
