Re: too shallow stack frame when using backtrace library under QNX650
04/08/2014 9:06 AM
post109848
The way bactktrace depth is being calculated in pidin has not changed
between 6.4.1 and 6.5.0.
The success of backtrace depends on the architecture. For example, on
arm, libbacktrace does not do a good job.
The difference in backtrace depth may be caused by the generated code
(i.e. different compilers used in 6.4.1 and 6.5.0), as libbacktrace
tries to decipher generated code which is very tricky.
On 14-04-08 07:06 AM, Adam Niezgoda wrote:
> When generating backtraces using backtrace library the stack frame is limited to 3 functions only for QNX650.
> It can also be seen when using pidin utility with %q format.
> For QNX641 the stack frames were deeper.
> Is there way to increase the limit under QNX650?
> Regards,
> Adam Niezgoda
> email: adam.niezgoda@delphi.com
> http://community.qnx.com/sf/go/post109841
> To cancel your subscription to this discussion, please e-mail momentics-community-unsubscribe@community.qnx.com
