Forum Topic - Use of select statement prevents multithreaded resource manager to catch SIGTERM:
I have noticed that in the context of a multithreaded resource manager, when the select() function is called to wait on
a file descriptor coming from pipe(), the main thread of the resource manager becomes unable to catch the SIGTERM signal
 when the process is slayed.
To reproduce this issue, I have attached a simple resource manager that calls select() on a fd from pipe() whenever a
read is performed. The select() call normally timeouts after 0.5 ms (results are the same whether I explicitly unblock
it or not). After that, if the resource manager process is slayed, the following message shows up:
# ./example_g &
# cat /dev/example
# slay example_g
Process 294931 (example_g) terminated SIGTERM code=0 by process 307220 value=0.
If the example is rebuilt with the select() call commented out, SIGTERM is correctly caught by the main thread, and this
 message is seen instead:
Termination Signal correctly received.
This issue is only seen if select() waits on an unnamed pipe. Other file descriptors do not prevent the main thread from
 catching SIGTERM.
Is this a bug in QNX 6.5.0 SP1, or is there something I am doing wrong?
Thanks for your help.
Attachment: Text example.c 6.41 KB
Re: Use of select statement prevents multithreaded resource manager to catch SIGTERM
The signal is received in both cases, just not by the same
thread.  If multiple threads have the signal unmasked
there's no guarantee which one will receive it.  A thread's
signal mask is inherited so you can mask off sigterm before
creating the threadpool then unmask it in the main.
on a file descriptor coming from pipe(), the main thread of the resource manager becomes unable to catch the SIGTERM
signal when the process is slayed.
> # ./example_g &
> # cat /dev/example
> # slay example_g
this message is seen instead:
from catching SIGTERM.
> http://community.qnx.com/sf/go/post106076
> To cancel your subscription to this discussion, please e-mail momentics-community-unsubscribe@community.qnx.com
Thanks Sean for your quick response. You are awesome - that was right on.
Best regards,
Vincent
>  the select() function is called to wait on a file descriptor coming from
> SIGTERM signal when the process is slayed.
> calls select() on a fd from pipe() whenever a read is performed. The select()
>  unblock it or not). After that, if the resource manager process is slayed,
> > # ./example_g &
> > # cat /dev/example
> > # slay example_g
> =0.
> correctly caught by the main thread, and this message is seen instead:
> descriptors do not prevent the main thread from catching SIGTERM.
