Forum Topic - Using Own Built Library: (2 Items)
I'm new to QNX, and I'm trying to do some simple experiment on QNX. I create two projects:
- SimpleLibrary, consisting of one object I created for learning purpose, compile it as Shared Library, no problem after
 compilation
- SimpleApplication, to use the SimpleLibrary. I add SimpleLibrary.so to the Linker, Extra object files, and I can
compile successfully.
However, when I tried to run the application, I got ":ldd:FATAL: Could not load library libSimpleLibrary.so" error. I
tried to copy all the file (.so, _g.so, and the application) to the virtual machine but I still got the same error. What
 should I do to  make it run?
Thank you
Re: Using Own Built Library
After searching from several sources, it looks like I put the file in a folder, and the LD_LIBRARY_PATH did not point to
 the directory. Now I can run it normally..
