Forum Topic - Slinger XHTML:
Slinger XHTML
i got a problem using a .xhtml-file as a root document.
Configuring slinger (Using QNX 6.5.0SP1) by Env-Vars works successfully and is can access my defined root-file from
network with an other pc, BUT the submited content from the webserver is declared as an "occtet-stream", is just can
save it as a file-download...
Is there any kind of configuration for the slinger-server to provide non html-file-types?
Is it required to define a specific DOCTYPE in order to slinger recognize the type right, an set the right type for the
transmit?
