Forum Topic - Remote Debugging Not Hitting Breakpoints: (2 Items)
I am debugging a program on a remote target and I can see the program running on the target but execution is not halting
 on any of the breakpoints I've set.  I can see them in the Breakpoints tab of the debugger perspective but the program
is not stopping.
Re: Remote Debugging Not Hitting Breakpoints
If I see this problem it is usually caused by the way my source code is mapped in the project.  Are you debugging the
source code from the same path you built it on?  If not you will need to set up a mapping in the debugger session
options.
If you are debugging from the same path the code was built on, then make sure you have selected "Use full file path to
set breakpoints" in the Debugger tab of Debugger Configurations.  Also, you should check out the Source Lookup Path
setting on the Source tab of Debugger Configurations.  For my project I have to use "Absolute File Path" there, but it
may be different for you.
