Forum Topic - Thread-Local Storage: gcc's __thread: (7 Items)
Is gcc's __thread keyword (http://gcc.gnu.org/onlinedocs/gcc-3.3.1/gcc/Thread-Local.html) supported in qnx neutrino?
Code such as
__thread int global=0;
compiles, but the assembler fails with errors such as "Error: junk `@NTPOFF' after expression".
Any help is greatly appreciated.
Sincerely, Thomas
Re: Thread-Local Storage: gcc's __thread
> Hello,
> Local.html) supported in qnx neutrino? Code such as
> after expression".
No, we don't have support for gcc's thread-local storage.
It shouldn't compile -- it should fail at the compiler stage not the assembler. Which compiler and target are you using?
qcc -V3.3.5,gcc_ntox86 tls.c
tls.c:1: error: thread-local storage not supported for this target
Ryan Mansfield
Thank you for the quick reply.
The following is a minimal example for triggering the error:
#include <pthread.h>
#include <stdlib.h>
#include <stdio.h>
__thread int tls=0;
void* fnc(void *arg);
int main(int argc,char**argv)
   pthread_t thread1;
   pthread_create(&thread1,0,fnc,0);
   printf("main tls= %d\n",tls);
   return EXIT_SUCCESS;
   int i;
   for(i=0;i<100;i++)
     tls++;
   printf("thread %d, tls= %d\n",pthread_self(),tls);
Compiling with
>> qcc -V3.3.5,gcc_ntox86  -S tls_minimal.c
on qnx 6.3.2 works.
However
>> gcc tls_minmal.s
>> qcc -V2.95.3,gcc_ntox86  -S tls_minimal.c
>> as  tls_minimal.s
all fail.
Will "__thread" be supported in the upcoming release (6.4.0 with gcc
4.2)?
Sincerely,
Thomas Buschmann
On Tue, 2008-03-25 at 09:15 -0400, Ryan Mansfield wrote:
> > Hello,
> > after expression".
using?
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post6091
Dipl.-Ing. Thomas Buschmann
Technische Universitaet Muenchen
Lehrstuhl fuer Angewandte Mechanik
Boltzmannstrasse 15, D-85747 Garching
Phone: +49 89/289-15228
Fax  : +49 89/289-15213
eMail: buschmann@amm.mw.tum.de
WWW  : http://www.amm.mw.tum.de/People/buschmann.html
> Compiling with
> on qnx 6.3.2 works.
Hmm, that's a bug. It should produced the not supported error message I pasted because we don't have the support for
gcc's tls support.
> However
> >> gcc tls_minmal.s
> >> as  tls_minimal.s
> all fail.
__thread wasn't introduced as a keyword until gcc 3 so this is expected.
> 4.2)?
I don't think the necessary OS support will make it in into 6.4 so unfortunately gcc 4.2 will have tls support disabled
as well.
Ryan Mansfield
Thanks a lot!
I'll just stick to POSIX functions then.
Sincerely,
Thomas Buschmann
On Tue, 2008-03-25 at 11:30 -0400, Ryan Mansfield wrote:
> > Compiling with
> > on qnx 6.3.2 works.
gcc's tls support.
> > However
> > >> gcc tls_minmal.s
> > >> as  tls_minimal.s
> > all fail.
> > 4.2)?
disabled as well.
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post6102
To use thread local storage you can use posix functions:
pthread_getspecific(), pthread_setspecific(), pthread_key_create(), and
pthread_key_delete() .
Attachment: Text elaskavaia.vcf 94 bytes
Thanks, I will do that.
I am interested in __thread, because it leads to better performance, at
least on linux.
> http://community.qnx.com/sf/go/post6104
