Forum Topic - IO-Address for mmap_device_io with PC-104: (7 Items)
I'm running QNX 6.5 on an Advantech PCM-3350 PC-104 stack with a Sensoray 526 Multifunction I/O card. It seems as though
 the best way to access the ports on this is through the registers, and it seems as though the best way to do that is by
 setting up with mmap_device_io(). However, I have no idea how to find base address for the IO card.
Any help would be greatly appreciated.
Re: IO-Address for mmap_device_io with PC-104
I saw a similar question recently and the answer referred to the manual
http://www.mathworks.com.au/support/solutions/en/data/1-57FT94/index.html?product=XP&solution=1-57FT94
Page 17
"Jumpers marked ADDR15-6 select the higher 10 bits of the board’s base address in I/O space.
Inserted jumper sets the corresponding bit to 0. The board ships with base address set to 0x2C0."
Great, thank you.
I probably read that a few times and didn't realize that was what I was looking for, I assumed the address was set by
the OS.
My next question involves the other input to mmap_device_io, the "length." Each register is 16 bits, so is the length 2
(2 bytes)? Or is it 27 ("Model 526 is controlled through a set of 27 registers mapped into I/O space")?
The registers are 16 bit (2 bytes) as you said.  There are 27 registers = 54 bytes.
This is supported by 6 low order address lines suggesting a maximum of 64 byte IO space.
Length = 54 bytes
uintptr_t   ioPtr = mmap_device_io (54, 0x2c0);    // for the factory supplied base address
Don't forget the     ThreadCtl(_NTO_TCTL_IO, 0)    call to get IO privileges.
Hmmm so I had been using
uintptr_t   ioPtr = mmap_device_io (2, 0x2c0);    // for the factory supplied base address
And it has been working fine for now, will this cause problems in the future?
Strictly - you should only be able to access the first register (Timer control) - anything else is outside the mapped
space and should fail with a SIGSEGV.
This suggests very loose limits checking!  For safety, don't depend on this behavior - it might be 'fixed' in a new
release/patch.
Ok great, thanks a lot for the help.
I'm working on a new problem now, in that I'm trying to use this system for real time control of a robotic system. I'd
like to have a control loop run at say 1khz, and maybe a loop that checks the sensors at some other frequency, I'm very
lost as to how to go about implementing this.
I can't really use the hardware counters/timers on the Sensoray 526 I have as I 3 of them for encoder inputs so I'd like
 to use another method. I find the documentation really lacking on how to go about doing this, should I use
InterruptAttach()? InterruptAttachEvent()? have the clock send a pulse or message?
I can't find any really good documentation or sample code for this sort of problem. I know people are doing things like
this and so it must not be that hard, but accurate loop timing is one of the reasons I decided to use the QNX RTOS.
