Forum Topic - momentics 4.5 will not open: (15 Items)
I just installed QNX 6.3.2 and Momentics 4.5
Now when I try to start Momentics the qde.exe process starts but ends before it gets to the workspace request screen
Any ideas on what would cause this?
Danny
RE: momentics 4.5 will not open
Check log file. What host are you using?
Re: RE: momentics 4.5 will not open
I can't seem to find a log file.  I know that when eclipse dies, it usually creates one, but this time it isn't giving
us any information.
We are running on Windows XP.
When I do a java -version I get:
java version "1.5.0_03"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_03-b07)
Java HotSpot(TM) Client VM (build 1.5.0_03-b07, mixed mode)
I have several java vms installed (two in the QNX632 directory, one for our automated testing software (IPL's Cantata++)
 and one that came with the tau release (the jre directory).
I'm wondering if the correct java vm is even being used by the tau release?
Below are my environment variables.
I can't think of anything else that might be helpful, so let me know if there is any other informaiton that might give
me a clue as to what is going on.
Thank you for your help,
Daniel
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\simlerd\Application Data
CLIENTNAME=Console
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=ARI-HOVER
ComSpec=C:\WINDOWS\system32\cmd.exe
FP_NO_HOST_CHECK=NO
HOME=C:\QNX630
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\simlerd
INCLUDE=c:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\include\
LIB=c:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\Lib\
LM_LICENSE_FILE=C:\Program Files\ipl\cantpp\lmgr\license.dat
LOGONSERVER=\\PENUMBRA
MAKEFLAGS=-IC:/QNX632/target/qnx6/usr/include
NUMBER_OF_PROCESSORS=2
OS=Windows_NT
Path=C:\Program Files\ipl\cantpp\bin;C:\Program Files\ipl\cantpp\jre\bin;;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\
System32\Wbem;C:\Program Files\Perforce;C:\P
rogram Files\Microsoft SQL Server\80\Tools\BINN;C:\Program Files\Microsoft SQL Server\90\Tools\binn\;C:\Program Files\
Perforce\;C:\Program Files\Birdstep Techno
logy\RDM Server 7.0\\bin;C:\QNX632\host\win32\x86\usr\bin;C:\Program Files\QNX Software Systems\bin;C:\Program Files\
Birdstep Technology\RDM Server 7.0\\bin
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.VBS
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 15 Model 4 Stepping 3, GenuineIntel
PROCESSOR_LEVEL=15
PROCESSOR_REVISION=0403
PROMPT=$P$G
QNX_CONFIGURATION=C:\Program Files\QNX Software Systems
QNX_HOST=C:/QNX632/host/win32/x86
QNX_JAVAHOME=C:\Program Files\QNX Software Systems\eclipsetau\jre
QNX_TARGET=C:/QNX632/target/qnx6
RDMSHOME=C:\Program Files\Birdstep Technology\RDM Server 7.0\
RDSHOME=C:\Program Files\Birdstep Technology\RDM Server 7.0\
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\simlerd\LOCALS~1\Temp
TMP=C:\DOCUME~1\simlerd\LOCALS~1\Temp
USERDNSDOMAIN=ARILABS.NET
USERDOMAIN=ARILABS
USERNAME=simlerd
USERPROFILE=C:\Documents and Settings\simlerd
VS71COMNTOOLS=c:\Program Files\Microsoft Visual Studio .NET 2003\Common7\Tools\
windir=C:\WINDOWS
One other tidbit, it will create a workspace folder (called ide-4.5-workspace) without promting.  It gets the org.
eclipse.core.resources and the org.eclipse.core.runtime folders created (in the .plugins folder along with version.ini
and .lock ) but that is about it.
Daniel
RE: RE: momentics 4.5 will not open
It may be java issue.
Run eclipse from console (instead of qde) with options -consolelog -debug
and check what it prints...
Re: RE: RE: momentics 4.5 will not open
Is there a way to make the console stay up?  The splash screen appears , the debug window comes up, prints some text and
 then disappears.
Daniel
RE: RE: RE: momentics 4.5 will not open
Are you running eclipse program? Not qde?
Re: RE: RE: RE: momentics 4.5 will not open
Thanks, I was still running qde.  Below is the output from the console debug running eclipse:
Daniel
Start VM: -Djava.class.path=C:\Program Files\QNX Software Systems\eclipsetau\plugins\org.eclipse.equinox.launcher_1.0.1.
R33x_v20070828.jar
-os win32
-ws win32
-arch x86
-showsplash
-launcher C:\Program Files\QNX Software Systems\eclipsetau\eclipsec.exe
-name Eclipsec
--launcher.library C:\Program Files\QNX Software Systems\eclipsetau\plugins\org.eclipse.equinox.launcher.win32.win32.
x86_1.0.2.R331_v20071019\eclipse_1021.dll
-startup C:\Program Files\QNX Software Systems\eclipsetau\plugins\org.eclipse.equinox.launcher_1.0.1.R33x_v20070828.jar
-console
-debug
-vm C:\QNX632\_jvm150_11-b03\bin\client\jvm.dll
-vmargs
R33x_v20070828.jar
Install location:
    file:/c:/Program Files/QNX Software Systems/eclipsetau/
Configuration file:
    file:/c:/Program Files/QNX Software Systems/eclipsetau/configuration/config.ini loaded
Configuration location:
    file:/C:/Documents and Settings/simlerd/momentics/4.5/configuration/
Configuration file:
    file:/C:/Documents and Settings/simlerd/momentics/4.5/configuration/config.ini not found or not read
Shared configuration location:
Framework located:
    file:/c:/Program Files/QNX Software Systems/eclipsetau/plugins/org.eclipse.osgi_3.3.1.R33x_v20070828.jar
Framework classpath:
Splash location:
    C:\Documents and Settings\simlerd\momentics\4.5\configuration\org.eclipse.equinox.launcher\com.qnx.tools.ide.
Debug options:
    file:/C:/Program Files/QNX Software Systems/eclipsetau/.options not found
osgi> Time to load bundles: 16
Starting application: 1796
Exception in thread "Thread-2" java.lang.NullPointerException
        at com.ipl.products.eclipse.cantpp.testscript.editting.ContextMenu.isEnabled(ContextMenu.java:268)
        at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:263)
        at org.eclipse.core.commands.Command.isEnabled(Command.java:831)
        at org.eclipse.core.commands.Command.setHandler(Command.java:969)
        at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:537)
        at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHandler(HandlerAuthority.java:186)
        at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:117)
        at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:109)
        at org.eclipse.ui.internal.handlers.HandlerPersistence.readHandlersFromRegistry(HandlerPersistence.java:289)
        at org.eclipse.ui.internal.handlers.HandlerPersistence.read(HandlerPersistence.java:194)
        at org.eclipse.ui.internal.handlers.HandlerService.readRegistry(HandlerService.java:182)
        at org.eclipse.ui.internal.Workbench$37.runWithException(Workbench.java:1575)
        at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
        at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
        at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:123)
        at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3659)
        at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3296)
        at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
        at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
        at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
        at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
        at...
RE: RE: RE: RE: momentics 4.5 will not open
And it is just dissapears after that? What is com.ipl.products plugin? I
don't think it is part of Tau.
Re: RE: RE: RE: RE: momentics 4.5 will not open
Yes, it just stops at that point with java vm version discussed in the other post.
The com.ipl plugins are part of the Cantata++ testing software that is built on eclipse.
RE: RE: RE: RE: RE: momentics 4.5 will not open
So if you run only Tau without additional plugins installed does it crash as
well?
Re: momentics 4.5 will not open
I just recalled that I linked the IPL Cantata++ plugins to Tau after I installed it.  It worked the first time, but
after I closed the IDE and restarted, it wouldn't open.  So I didn't think about Cantatta, sorry abou the false alarm.
I ran Tau using 1.4.2 Java vm, disabled the plugins and ran using 1.5.0 Java vm.  It works fine now.
I need to inform IPL of our issues and need to communicate the version of CDT used in Tau.  Is there a way to export the
 plug-in names and versions into a text file or to the clipboard so I can email them this information?
Daniel
If you do Help->About->Configuration Details it should list plugins, you can
copy this file to clipboard
That worked.  We were able to send IPL the information.
Thank you for your help.
Okay, I think we have it figured out and you may be able to use what we discovered.
4.5 Tau won't run on our maching with the jre provide with tau (java version 1.5.0_11-b03).  We have two installations
of java version 1.5.0  (_03-b03 and _11-b03).  Neither will work with Tau.
It is running fine with Java version 1.4.2
Daniel
