Dinkum Abridged with Mudflap
12/09/2011 8:17 PM
post90514
Hello, I'm running into an issue using Mudflap and I am wondering if I missed something or if anyone else ran into the
same issue.
I created a "hello world" program to test out the Mudflap debugging capabilities. It is a simple program that uses a
std::cout and a some catch bug like accessing after free.
*If I use the GNU CPP libraries, everything works fine. It reports the error without any false positives.
*If I use anything else (in this case, Dinkum Abridged without exceptions), it reports numerous memory errors within the
use of std::cout. (The majority of them seem to trace back to static construction)
Question:
Is Mudflap compatible with CPP libraries other than GNU's?
I apologize if I missed something obvious. (It happens often) :)
Extra info:
I'm using QNX 6.5 / Momentics 4.7.2 / GNU Compiler Collection (4.4.2)
Thanks!
Michael.
