08/30/2011 7:29 AM
post88480
//code
/*#include <spawn.h>
#include<stdio.h>
#include<stdlib.h>
#include<unistd.h>
int main(int argc,char **argv)
char *args[]={"child",NULL};
int i;
pid_t pid;
struct inheritance inherit;
for (i=0;i<3;i++)
inherit.flags |= SPAWN_EXEC;
if((pid=spawn("sharedmemorymodel",0,NULL,&inherit,args,environ))==-1)
perror("spawn failed");
else
printf("the spawn id %d",pid);
return 0;
i have tried this code in qnx momentics and i used vmware to run qnx rtos.. while executing this code i got error like
spawn:not supported.. couldn't find out what is the problem.. whether running in windows, executing qnx exe is not
supportable? or some other problem. pls help me asap
thanks in advance,
shakthi
Re: spawn system call error
08/30/2011 7:34 AM
post88481
how about a memset(&inherit, 0, sizeof(struct inherit)) ? :-)
> //code
> #include<stdio.h>
> #include<stdlib.h>
> #include<unistd.h>
> int i;
> pid_t pid;
> for (i=0;i<3;i++)
> else
> return 0;
> while executing this code i got error like spawn:not supported.. couldn't find
> not supportable? or some other problem. pls help me asap
> thanks in advance,
> shakthi
08/30/2011 7:37 AM
post88482
ups,
I mean:
how about a memset(&inherit, 0, sizeof(inherit));
08/30/2011 7:41 AM
post88483
no dude. i ve tried i got some error like:
spawn : no such file or directory..
dont know what to do??
08/30/2011 7:53 AM
post88485
What do you expect to get?
Setting SPAWN_EXEC means you want to replace the current process with a new one.
In argv[0] you set 'child' but in the path you set 'sharedmemorymodel'.
So what do you expect from this program?
If you want to search the PATH variable for the executable you want to replace the running process with, you should use
the spawnp() variant.
> > //code
> > #include<stdio.h>
> > #include<stdlib.h>
> > #include<unistd.h>
> > int i;
> > pid_t pid;
> > for (i=0;i<3;i++)
> > else
> > return 0;
> find
> > thanks in advance,
> > shakthi
08/30/2011 7:59 AM
post88486
//code
#include<stdio.h>
#include<stdlib.h>
#include<unistd.h>
char *args[]={"spawnexample",NULL};
int i;
pid_t pid;
inherit.flags =0;
if((pid=spawn("spawnexample",0,NULL,&inherit,args,0))==-1)
else
return 0;
k dude i changed my code
my program name is spawnexample.. i need this pgm should create one child process and that process execute my same
program..now also am facing same error..
08/30/2011 8:09 AM
post88487
> //code
> #include<stdio.h>
> #include<stdlib.h>
> #include<unistd.h>
> int i;
> pid_t pid;
> inherit.flags =0;
> else
> return 0;
> process and that process execute my same program..now also am facing same
> error..
you don't get a child process that way. As I said in the previous post, the SPAWN_EXEC flags _REPLACES_ your _CURRENT_
executable. spawn doesn't return at all.
BTW: The first argument <path> must be an absolute path to the executable as described in the documentation.
08/30/2011 8:11 AM
post88488
see now i removed the flag and set it as zero and also change the argument as executable that is my current pgm name...
see the code properly.. still i face the same error.
08/30/2011 8:13 AM
post88489
> executable that is my current pgm name... see the code properly.. still i face
> the same error.
the path is still relative not absolute.
whether use spawnp to search in the PATH environment (if it points to your executable) or make the path an absolute path
08/30/2011 8:17 AM
post88490
i dint understood dude.. can you change my code and post it here.. where to change.. see it automatically locate the
path rite.. then y should i have to specify path and it will not accept the path of the windows rite..
08/30/2011 8:21 AM
post88491
> change.. see it automatically locate the path rite.. then y should i have to
#include <stdlib.h>
#include <stdio.h>
#include<unistd.h>
#include <spawn.h>
int main(int argc,char **argv) {
char *args[]={"hello_g",NULL};
int i;
pid_t pid;
inherit.flags =0;
if((pid=spawn("/tmp/hello_g",0,NULL,&inherit,args,0))==-1)
else
return 0;
you can't start a QNX executable on windows.
Please start this program on QNX natively from /tmp directory.
So you should have:
/tmp/hello_g as an executable on a QNX RTOS.
