Forum Topic - rtkit install from usb flash?: (8 Items)
Has anyone done this? I tried by:
  formatting drive with QNX4 using the boot file extracted from instflop-rtkit.dat
  copying over the regular rtkit files, including rtinstall, boot/fs/*.ifs,*.qfs
The drive boots, but it does not get into the rtinstall script. I'm *guessing* it somehow isn't finding the USB drive
after booting. Do I need to build a more carefully customized boot image?
Re: rtkit install from usb flash?
Most likely. When I wrote it it was intended for customization by the
distributor. I'm fairly certain I hardcoded lots of /fs/cd0's in there.
> instflop-rtkit.dat
> boot/fs/*.ifs,*.qfs
> http://community.qnx.com/sf/go/post88372
RE: rtkit install from usb flash?
We found that 6.4.1 would not find rtinstall on a USB CD, but 6.5.0
would.
From: Keith Russell [mailto:community-noreply@qnx.com]
Sent: Thursday, August 25, 2011 3:07 PM
To: momentics-community
Subject: Re: rtkit install from usb flash?
> instflop-rtkit.dat
> boot/fs/*.ifs,*.qfs
*guessing*
image?
http://community.qnx.com/sf/go/post88374
Keith, When you say "when I wrote it", are you referring to diskboot, the rtkit technote or the instflop.dat boot image?
 (or something else)
All three, though diskboot I inherited. But in this case I'm only referring
to the script and the technote. I am pretty sure it's possible but I can't
remember right now. It may be just waiting for /fs/usb* and mounting it. The
'rtinstall' is just a shell script. Nothing fancy.
Keith
> rtkit technote or the instflop.dat boot image? (or something else)
> http://community.qnx.com/sf/go/post88376
Yeah, I have customized rtinstall, and it works well for CD installs (and not a sign of /fs/cd0 there at least). I don't
 think I'm getting that far, which makes me think the problem might be in diskboot.
diskboot seems to be a little bit of a mystery, since it must be doing some of the things that enum-devices does, but
with less configurability. But without configurability, I can't tell it to wait, right?
And that would point the way to a boot image that skips diskboot, starts the drivers I need, waits for /fs/umass0 or
whatever, and runs rtinstall. Does that seems like the most straightforward approach?
Did you find a solution for this? I want to do the same thing.
Yes, although it is not a very robust solution. It works for certain specific flash drives some of the time. A more
robust solution would probably require matching the driver settings to the flash drive, and build a custom boot image
for each drive. I am attaching the build file I used, which is a fairly straightforward modification of the rtkit
example.
Attachment: Text usbinst.build 4.07 KB
