Regarding QNX 6.3.2 Header files
08/09/2011 12:21 AM
post87911
I am new to QNX. I am trying to port an application on QNX 6.3.2. When I am trying to port I am facing with redefinition
errors with system header files. For example,
In sys/time.h, we have a structure named timeval:
struct timeval {
_CSTD time_t tv_sec; /* seconds */
suseconds_t tv_usec; /* microseconds */
I have the same definition in my own application also like:
typedef struct timeval
UINT4 tv_sec; /* Time in Seconds */
UINT4 tv_usec; /* Time in Microseconds */
} timeval;
When I compile, I am facing with redefinition erros.
I am unable to suppress the inclusion of system header files when I compile from top level as other modules are also
requiring it.
I cross-checked the definition of timeval structure in Linux Header file: /usr/include/bits/time.h
# ifndef _STRUCT_TIMEVAL
# define _STRUCT_TIMEVAL 1
# include <bits/types.h>
/* A time value that is accurate to the nearest
microsecond but also has a range of years. */
struct timeval
__time_t tv_sec; /* Seconds. */
__suseconds_t tv_usec; /* Microseconds. */
# endif /* struct timeval */
#endif /* need timeval */
In Linux, they have a flag to check for the redefinition of structure.(_STRUCT_TIMEVAL ).But in QNX I am unable to find
such a flag. Due to this,I am doing lots of patch work in my application.I am not sure how to avoid such kind of errors.
Please clarify me with a solution.Is there any better way to avoid it?
