Forum Topic - Momentics compiler doesn't recognize PhAB types?: (8 Items)
I wonder if somebody can help me with this. I'm developing a Photon Appbuilder project in QNX Momentics v6.3. During the
 project build
I'm getting these errors that make it look as if the compiler didn't recognize any PhAB types, such as ApWidget_t. For
example, I get the following compiler error
data definition has no type or storage class abwidgets.h
The line producing the error is:
ApWidget_t AbWidgets[ 68 ];
which is the only line in abwidgets.h
apparently the compiler is not recognizing the type ApWidget_t even though Appbuilder has included Photon library
headers in the project. In fact, the header file Ap.h appears in the list of includes for the project. Can anyone tell
me what's wrong?
RE: Momentics compiler doesn't recognize PhAB types?
Can you post the output from the make command?
From: Gabriel Aguirre-Ollinger [mailto:gaguirre@northwestern.edu]
Sent: Wednesday, February 13, 2008 2:46 PM
To: momentics-community
Subject: Momentics compiler doesn't recognize PhAB types?
Appbuilder project in QNX Momentics v6.3. During the project build
recognize any PhAB types, such as ApWidget_t. For example, I get the
Appbuilder has included Photon library headers in the project. In fact, the
tell me what's wrong?
http://community.qnx.com/sf/go/post5008
Re: RE: Momentics compiler doesn't recognize PhAB types?
Hi: I'm not sure if you mean the console output. In that case this is what i get:
C:/app_exo2/src/abwidgets.h:3: parse error before `AbWidgets'
C:/app_exo2/src/abwidgets.h:3: warning: type defaults to `int' in declaration of `AbWidgets'
C:/app_exo2/src/abwidgets.h:3: warning: data definition has no type or storage class
This is the whole abwidgets.h file:
/* Widget header for application - AppBuilder 2.03  */
I get this other error in abimport.h:
C:/app_exo2/src/abimport.h:5: parse error before `AbInternalLinks'
C:/app_exo2/src/abimport.h:5: warning: type defaults to `int' in declaration of `AbInternalLinks'
C:/app_exo2/src/abimport.h:5: warning: data definition has no type or storage class
The line in question is:
extern ApEventLink_t AbInternalLinks[];
It must be that your Ap.h file is damaged or is not being picked up from the correct location. Usually ablibs.h includes
 this header.
To see what is going on, you can view the output of the preprocessor. If you cannot resolve the problem, try posting the
 preprocessed file here.
One way to get the output of the preprocessor is to use the following option to qcc: -Wc,-save-temps
This will leave behind temporary files in the compilation directory.
Max
Well, the IDE installation is brand new, and the automatically generated list of included files in the C/C++ Project
contains the correct path to Ap.h. The source code for Ap.h is there. So why is the compiler behaving as if it can't
find Ap.h?
If I could always tell someone why a compiler behaves unexpectedly, I'd be a rich man.
Because I can't do this without more information, the most useful thing to me would be to see the preprocessor output.
Max
I'm not sure how to generate the preprocessor output because I'm not using my own makefiles. Is there for example a way
to make the IDE build a project with an user-supplied makefile?
Gabriel
> own makefiles.
Use the -E compiler option to tell the qcc/gcc drivers to stop after preprocessor stage.
Ryan Mansfield
