Re: Integration with source control
05/16/2011 8:53 AM
post85703
Hi, Greg,
In general, nothing from the workspace's .metadata folder is expected to be managed in source control. The vast
majority of the data in there comprises four categories of volatile and user-specific information:
- record of which projects are instantiated in the workspace
and where on the filesystem its resources are stored
- caches of computed information, such as the build state
of projects, indexes for fast searching, etc.
- user preferences for layout of the user interface, records
of user input into dialogs and wizards, and other options
- logging/diagnostic information
Anything from the workspace folder that you might want to share with a team usually provides a better way than sharing
the workspace metadata:
- project-set files (*.psf) provide a means to share with a
team a set of projects with the SVN URLs from which
they are checked out
- preferences such as common toolchain/compiler settings,
code templates, and the like can be shared via export to
*.epf files. Although, most preferences can also be
maintained within the projects, which are already shared
in SVN
HTH,
Christian
On 2011-05-16, at 4:41 AM, Gregoire Banderet wrote:
> Hello,
> We are using Momentics (Eclipse / CDT) for our C/C++ projects, and Subversion as source control system.
> We checked-in .cproject and .project files into SVN.
> And we are wondering which fiels from the .metadata folder we should also check-in?
> Some files contain absolute paths to the workspace, and all the developer do not have the same directory structure...
> So what the common way to work with Momentics and source control?
> Thanks,
> Greg
> http://community.qnx.com/sf/go/post85698
Christian W. Damus
Software Developer, IDE Team
QNX Software Systems <http://www.qnx.com/>
