Forum Topic - Debugging on a 6.2.1 target using Momentics 4.0.1?: (5 Items)
Hi all,
I'm having problems debugging on a 6.2.1 target using the 4.0.1 IDE.
I get "Error getting remote environment" and the process terminates without actually being executed. This is only an
HelloWorld test app.
I can succesfully debug the same test app on the same target using the 3.0.0 IDE.
Any clues anyone?
Martin
RE: Debugging on a 6.2.1 target using Momentics 4.0.1?
You need to update qconn binary component on target. New ide cannot use
qconn from 6.2.1
From: Martin Gagnon [mailto:martin.gagnon@genisys.qc.ca]
Sent: February 7, 2008 3:57 PM
To: momentics-community
Subject: Debugging on a 6.2.1 target using Momentics 4.0.1?
Hi all,
actually being executed. This is only an HelloWorld test app.
IDE.
Any clues anyone?
Martin
http://community.qnx.com/sf/go/post4863
Re: RE: Debugging on a 6.2.1 target using Momentics 4.0.1?
The Target Properties tells me that qconn is up to date on the target though, and the System Information perspective
works very well with that 621 target.
However, when I try the 632 version of qconn on the 621 target, it will not run: 'Could not resolve all symbols'.
Running objdump -x qconn.632 | grep NEEDED shows:
objdump: qconn.632: no symbols
  NEEDED      libsocket.so.2
  NEEDED      libc.so.2
The 621 target has these 2 libs in places included in LD_LIBRARY_PATH.
Should they be updated as well?
Martin
>   NEEDED      libc.so.2
632 binaries may not work on 621.  I think what's needed is the head
branch qconn compiled on a 621 system.
Re: Debugging on a 6.2.1 target using Momentics 4.0.1?
 IDE 4.0.1 does not officially support 6.2.1 targets...
Some other things you can do with launching debugger: you can try to debug attaching to already running process or run
pdebug over serial port
