Forum Topic - Problem building project: error in make command: (13 Items)
I recently donwload the 30days trial version of QNX Momentics 6.5.0 for Windows host. I get started trying to compile my
 first "Hello world" app but I get some errors in building project
%INSTALL_PATH%\host\win32\x86\usr\bin\make.exe -k CPULIST=x86 all --file=%MY_USER_APP%/Local/Temp/
QMakefile129733018063912583.tmp
%INSTALL_PATH%/host/win32/x86/usr/bin/make.exe -j 1 -Cx86 -fMakefile all
make.exe[1]: Entering directory `%MY_WORKSPACE%/My_Project/x86'
Makefile:8: recurse.mk: No such file or directory
make.exe[1]: *** No rule to make target `recurse.mk'.
make.exe[1]: Failed to remake makefile `recurse.mk'.
make.exe[1]: *** No rule to make target `all'.
make.exe[1]: Leaving directory `%MY_WORKSPACE%/My_Project/x86'
make: [all] Error 2 (ignored)
Note: to be short I modified some subpath with %VAR%
Re: Problem building project: error in make command
Make does know anything about %VAR%, momentics build system does not use "cmd" shell, it using unix still shell and make
my first "Hello world" app but I get some errors in building project
> http://community.qnx.com/sf/go/post83067
I just replace some piece of path with %VAR% when I past the error message just to be short.
For example: instead of C:\Program Files\QNX Momentics 6.0.5\... I write in %INSTALL_PATH%, but just to be short. In the
 error message given by make all paths are full, not with %VAR%
How you building? From command line? From IDE?
Do you have MAKEFLAGS var set?
the error message given by make all paths are full, not with %VAR%
> http://community.qnx.com/sf/go/post83075
I build from IDE and the MAKEFLAGS is set to -ID:/Program Files/x86/QNX Momentics 6.0.5/target/qnx6/usr/include/
The IDE builder can't find recurse.mk that is in D:/Program Files/x86/QNX Momentics 6.0.5/target/qnx6/usr/include/mk/
Now I'm trying to install Momentics Tools Suite under linux and see if I get the same problems.
Thanks for help
You mean 6.5.0? Because there is no 6.0.5
> Thanks for help
> http://community.qnx.com/sf/go/post83080
Ok..the actual version is 6.5.0 but I made a mistake writing the installation folder when I setup the IDE. May this
cause any problem?? I hope not...
I can imagine that the space in the target directory path would cause trouble for make.  Makefiles typically tokenize
lists and such on whitespace.
Cheers,
Christian
> Thanks for help
Bingo!! You were right. The problem was that. I have uninstalled the suite and reinstalled again, following the
suggestion ( c:\QNX650 ) when the installation procedure asks me the installation folder...and everything went fine!
Thanks so much Christian, and also Elena, for your support.
I have the same issue under Ubuntu 12.04. I installed 6.5.0 with SP1 in "/opt/qnx650".
What might be the issue in my case then?
i used sudo -E for installing SP1 and the problem is fixed now.
I still have this problem after reinstalling with sudo -E Qnx650 SP1 on Ubuntu 14.04.
Do you have any idea?
Thank you
The most common problem I see is:
Install 6.5.0 (with -E) and then immediately installing 6.5.0 SP1 (also with -E). You MUST log out and in before
installing 6.5.0SP1.
I don't know if this applies to your case of not, but I've seen it often enough that it's a good first check.
- Shawn
