Forum Topic - Thead naming: (4 Items)
Thead naming
qnx 6.3.2 kernel now supports naming of a thread via function
pthread_setname_np()
I have problem using this function when debugging in Momentics IDE, and it gives me error code EBUSY ("Device or
resource busy").
But when I run (instead of debugging) in IDE, it works fine. And, if I run the binary directly on a QNX target, it also
works just fine.
Any idea?
My Momentics is carried on a WindowXp machine.
Thanks.
RE: Thead naming
What is the target platform? X86? Does you host installation matches with
target (version)? Could be some weird binary incompatibility with
debugger...
(I used this function without any problems in my setup)
RE: Thead naming
Hi Zhenwang,
What you're seeing is a known issue, and is covered under PR/38578:
pthread_setname_np fails with child resource busy when debugging in IDE
This is a kernel issue, and scheduled to be fixed in a future release. If
you require a fix in the short term, please contact your QSS sales
representative and discuss support options.
Cheers,
-Brian
> From: Elena Laskavaia [mailto:elaskavaia@qnx.com]
> Sent: Thursday, January 24, 2008 10 11
> To: momentics-community
> Subject: RE: Thead naming
> matches with
> debugger...
> http://community.qnx.com/sf/go/post4556
Re: RE: Thead naming
Hi Brian,
Thank you very much!
Zhenwang.
> Hi Zhenwang,
> Cheers,
> -Brian
