Momentics 4.6 doesn't start
10/17/2010 2:04 PM
post70985
Hi there,
since I have some problems with connecting to a Neutrino641Target when running Momentics under Linux 64bit, I did an
install on another computer which runs Linux 32bit (kernel 2.6.34) to see if that fixes the issue. The problem now is,
that Momentics installs and activates just fine - but refuses to start. If I try to run it, the splashscreen appears and
after it disappears a really small, empty window is coming up showing only "QDE" in the titlebar. That's it! Nothing
more. The process doesn't eat up any CPU time or anything. It just shows this small window. Btw. I can't close this
window. I have to kill the entire process instead. Right now I'm close to giving up and cease the course I'd need
Momentics for. It's now more than 20 hours that I try to get something to work.
Please help me.
Thanks a lot in advance.
Regards
Max
