Porting from 6.2.1A to 6.5
09/15/2010 6:03 PM
post67512
Hello All
We have upgraded our host from an old Windows 2000 machine to a brand new Windows XP 64 machine. Along with the host
upgrade we decided to renew QNX support and are attempting to port our project over to 6.5.
The target is a x86 processor (Ampro, no BSP) and the QNX OS runs on a flash drive. We use an FTP server on both sides
and compile builds using the command prompt. The flash drive is formatted with a QNX based file system; no doubt this
needs upgrading.
6.5 installed easily on the new machine. We transferred the directory (just the basics) from the old machine with the
intent to change as little source code as possible. About the only difference is the top-most file, QNXsdk, was changed
to QNX650. Utilizing Windows environmental variables we changed QNX650 back to QNXsdk; much easier than changing dozens
and dozens of files to 650. All the paths are good and we were able to compile an image file. When we send the file to
the target the BIOS starts up and then it craps out; nothing happens.
We ported over the old start up BIOS and the old procnto and were able to run a simple hello world program via the alt.
boot option, but that is it. Are there new switches or drivers or whatever that we need? Is this something that will be
simple to solve? Do we need to purchase Gold support?
Attached is our build file.
Thanks.
