Forum Topic - Segfault in operator << of ostringstream:
Hi, I'm using C++ on QNX 6.3.2 and I got a segfault when doing "<<" in a ostringstream.
I've had a similar problem before[1] but it was because some library I was linking to was compiled against Dinkumware C+
+ Library and GNU C++ library, and there is a problem with Dinkumware C++ Library and multi-threaded programs (my
program is multi-thread). This problem in the library I was linking to was fixed (only links against GNU C++ if I'm not
wrong), but now I'm hitting a strange segfault too. Here is the backtrace:
(gdb) bt
#0  0xb0320ce4 in __flist_dequeue_bin () from /usr/qnx632/target/qnx6/x86/lib/libc.so.2
#1  0xb0320791 in _list_release () from /usr/qnx632/target/qnx6/x86/lib/libc.so.2
#2  0xb0320f41 in __prelocked_free () from /usr/qnx632/target/qnx6/x86/lib/libc.so.2
#3  0xb0320ff0 in __free () from /usr/qnx632/target/qnx6/x86/lib/libc.so.2
#4  0xb031ea4e in free () from /usr/qnx632/target/qnx6/x86/lib/libc.so.2
#5  0xb824a718 in __builtin_vec_delete (ptr=0x8000004) at ../../gcc/cp/new2.cc:62
#6  0x080553d4 in stringbuf::overflow (this=0x7fa5ea4, c=124) at /opt/qnx632/target/qnx6/usr/include/g++-3/sstream:112
#7  0xb823b51d in __overflow () at ../../../../libstdc++/std/std_valarray.h:268
#8  0xb823b97c in _IO_default_xsputn () at ../../../../libstdc++/std/std_valarray.h:268
#9  0xb8244130 in streambuf::xsputn (this=0x7fa5ea4,
    s=0x8202028 "CAL08|BAL01I|197.415|1282963716|A|0\nCAL08|BAL01I_F|NaN|1257376016|A|0\nCAL08|BAL02I|123.505|1282963716
|A|0\nCAL08|CD10_BTF1P_C|0|0|A|12\nCAL08|CD10_MATIAEP|0|0|A|12\nCAL08|CD10_MATIAOP|0|0|A|12\nCAL08|CD10"..., n=75290) at
 ../../../../libio/streambuf.cc:69
#10 0xb8242bdb in ostream::write (this=0x7fa5ea0,
 ../../../../libio/iostream.cc:1004
#11 0x080538f6 in ostream & operator<<<char, string_char_traits<char>, __default_alloc_template<true, 0> > (o=@0x7fa5ea0, s=@
0x7fa5e94)
    at /opt/qnx632/target/qnx6/usr/include/g++-3/std/bastring.cc:470
#12 0x08050db5 in UI_Comm::interpret_tokens (this=0x809b1a8, tokens=
          {<_Vector_base<basic_string<char,string_char_traits<char>,__default_alloc_template<true,0> >,allocator<
basic_string<char,string_char_traits<char>,__default_alloc_template<true,0> > > >> = {<_Vector_alloc_base<basic_string<
char,string_char_traits<char>,__default_alloc_template<true,0> >,allocator<basic_string<char,string_char_traits<char>,
__default_alloc_template<true,0> > >,>> = {_M_start = 0x7fa5f48, _M_finish = 0x0, _M_end_of_storage = 0x0}, <No data
fields>}, <No data fields>})
    at ui_comm.cc:206
#13 0x08051bd5 in UI_Comm::run (this=0x809b1a8) at ui_comm.cc:335
#14 0x08051a3a in UI_Comm::thread_run (arg=0x809b1a8) at ui_comm.cc:296
Till #12 is my program, after that it is inside the C++ library if I'm not wrong.
In this backtrace libcpp.so is not listed (at least directly, as it was in [1]) but I wanted to know if someone knows
something (perhaps something in the backtrace, that I don't know, is using libcpp ?) or is it a known problem that will
be fixed on an update ?
Thanks a lot,
Rodrigo
[1]: http://community.qnx.com/sf/discussion/do/listPosts/projects.community/discussion.qnx_momentics_community_support.
topc9455
RE: Segfault in operator << of ostringstream
From memory this was the same issue I had with dinkumware and multithread program...  Fix was to upgrade to 6.4.1 ;-)
-----Message d'origine-----
De : Rodrigo Campos [mailto:community-noreply@qnx.com]
Envoyé : 31 août 2010 14:43
À : momentics-community
Objet : Segfault in operator << of ostringstream
(gdb) bt
0x7fa5e94)
    at ui_comm.cc:206
Thanks a lot,
Rodrigo
topc9455
QNX Momentics Community...
Re: RE: Segfault in operator << of ostringstream
But I'm not using dinkumware. I'm using the GNU C++ std library.
I've had a similar issue, but it was that a library I was linking to was linked against dinkumware[1]. Now that this
issue is fixed in the library, I'm seeing this backtrace.
I will recheck (I will not have access to the machine till tomorrow) if the fixed library is installed (and fixed), but
as the operator told me it was installed, I thought that, perhaps, there was some other issue.
Thanks a lot for your help, I will update the status tomorrow :)
Rodrigo
topc9455
> fixed library is installed (and fixed), but as the operator told me it was
Yes, the libraries I'm linking to does not link against libcpp.so
Here is the output of ldd of my binary:
	libscanner.so => /opt/rf6/lib/libscanner.so (0xb8200000)
	libstdc++.so.2.2.10.0 => /lib/libstdc++.so.2.2.10.0 (0xb821d000)
	libm.so.2 => /lib/libm.so.2 (0xb826b000)
	libsocket.so.2 => /lib/libsocket.so.2 (0xb8287000)
	librf.so.1 => /opt/rf6/lib/librf.so.1 (0xb82ab000)
	librfio.so => /opt/rf6/lib/librfio.so (0xb8315000)
	libauth.so => /opt/rf6/lib/libauth.so (0xb831f000)
	libhsc.so => /opt/rf6/lib/libhsc.so (0xb832c000)
	libph.so.3 => /usr/lib/libph.so.3 (0xb8337000)
	libphexlib.so.3 => /usr/lib/libphexlib.so.3 (0xb8437000)
	librftrans.so => /opt/rf6/lib/librftrans.so (0xb8462000)
	libflex.so => /opt/rf6/lib/libflex.so (0xb846e000)
	librfhist.so => /opt/rf6/lib/librfhist.so (0xb84da000)
And here is the output of the libraries:
# ldd /opt/rf6/lib/lib*
/opt/rf6/lib/libauth.so:
	libauth.so => /opt/rf6/lib/libauth.so (0xb8200000)
	librf.so.1 => /opt/rf6/lib/librf.so.1 (0xb820d000)
	librfio.so => /opt/rf6/lib/librfio.so (0xb8277000)
	libsocket.so.2 => libsocket.so.2 (0xb8281000)
	libm.so.2 => libm.so.2 (0xb82a5000)
	libcpp.so.3 => libcpp.so.3 (0xb82c1000)
	libhsc.so => /opt/rf6/lib/libhsc.so (0xb8335000)
	libstdc++.so.2.2.10.0 => libstdc++.so.2.2.10.0 (0xb8340000)
/opt/rf6/lib/libcomm.so:
	libcomm.so => /opt/rf6/lib/libcomm.so (0xb8200000)
/opt/rf6/lib/libflex.so:
	libflex.so => /opt/rf6/lib/libflex.so (0xb8200000)
	libm.so.2 => libm.so.2 (0xb826c000)
	libsocket.so.2 => libsocket.so.2 (0xb8288000)
	librf.so.1 => /opt/rf6/lib/librf.so.1 (0xb82ac000)
	librfio.so => /opt/rf6/lib/librfio.so (0xb8316000)
	libauth.so => /opt/rf6/lib/libauth.so (0xb8320000)
	libflexuuid.so => /opt/rf6/lib/libflexuuid.so (0xb832d000)
	libcpp.so.3 => libcpp.so.3 (0xb8331000)
	libhsc.so => /opt/rf6/lib/libhsc.so (0xb83a5000)
	libstdc++.so.2.2.10.0 => libstdc++.so.2.2.10.0 (0xb83b0000)
	librfcrypt.so => /opt/rf6/lib/librfcrypt.so (0xb83fe000)
/opt/rf6/lib/libflexipc.so:
	libflexipc.so => /opt/rf6/lib/libflexipc.so (0xb8200000)
	libm.so.2 => libm.so.2 (0xb8207000)
	libsocket.so.2 => libsocket.so.2 (0xb8223000)
	librf.so.1 => /opt/rf6/lib/librf.so.1 (0xb8247000)
	libcpp.so.3 => libcpp.so.3 (0xb82b1000)
	libhsc.so => /opt/rf6/lib/libhsc.so (0xb8325000)
	libstdc++.so.2.2.10.0 => libstdc++.so.2.2.10.0 (0xb8330000)
/opt/rf6/lib/libflexuuid.so:
	libflexuuid.so => /opt/rf6/lib/libflexuuid.so (0xb8200000)
	libsocket.so.2 => libsocket.so.2 (0xb8204000)
	librfcrypt.so => /opt/rf6/lib/librfcrypt.so (0xb8228000)
	libcpp.so.3 => libcpp.so.3 (0xb823b000)
/opt/rf6/lib/libfwhist.so:
	libfwhist.so => /opt/rf6/lib/libfwhist.so (0xb8200000)
	libflex.so => /opt/rf6/lib/libflex.so (0xb826b000)
	libcpp.so.3 => libcpp.so.3 (0xb82d7000)
	libm.so.2 => libm.so.2 (0xb834b000)
	libsocket.so.2 => libsocket.so.2 (0xb8367000)
	librf.so.1 => /opt/rf6/lib/librf.so.1 (0xb838b000)
	librfio.so => /opt/rf6/lib/librfio.so (0xb83f5000)
	libauth.so => /opt/rf6/lib/libauth.so (0xb83ff000)
	libflexuuid.so => /opt/rf6/lib/libflexuuid.so (0xb840c000)
	libhsc.so => /opt/rf6/lib/libhsc.so (0xb8410000)
	libstdc++.so.2.2.10.0 => libstdc++.so.2.2.10.0 (0xb841b000)
	librfcrypt.so => /opt/rf6/lib/librfcrypt.so (0xb8469000)
/opt/rf6/lib/libhsc.so:
	libhsc.so => /opt/rf6/lib/libhsc.so (0xb8200000)
	libstdc++.so.2.2.10.0 => libstdc++.so.2.2.10.0 (0xb820b000)
	libm.so.2 => libm.so.2...
