Forum Topic - EXTRA_INCVPATH & EXTRA_LIBVPATH in common.mk: (4 Items)
I am curious to know what EXTRA_INCVPATH & EXTRA_LIBVPATH in common.mk of a project mean? What happens when a library's
path is added to EXTRA_INCVPATH and what happens when the library's path is added to EXTRA_LIBVPATH?
I have seen number of projects where a particular library's path is added to EXTRA_INCVPATH & EXTRA_LIBVPATH. For
example:
EXTRA_INCVPATH+=$(PROJECT_ROOT_mylibapi)
EXTRA_LIBVPATH+=$(PROJECT_ROOT_mylibapi)/$(CPU)/so
I am looking a comprehensive explanation for these. So any information would be appreciated.
Sunil
Re: EXTRA_INCVPATH & EXTRA_LIBVPATH in common.mk
On Wed, 2010-08-18 at 09:44 -0400, Sunil Keshava wrote:
> Hello,
> I am curious to know what EXTRA_INCVPATH & EXTRA_LIBVPATH in common.mk of a project mean? What happens when a library's path is added to EXTRA_INCVPATH and what happens when the library's path is added to EXTRA_LIBVPATH?
> I have seen number of projects where a particular library's path is added to EXTRA_INCVPATH & EXTRA_LIBVPATH. For example:
> Thanks
> Sunil
EXTRA_INCVPATH
        Added to INCVPATH just before the $(USE_ROOT_INCLUDE). Default
        is none.
EXTRA_LIBVPATH
        Added to LIBVPATH just before
        $(INSTALL_ROOT_support)/$(OS)/$(CPUDIR)/lib. Default is none.
You can read more about it here:
http://www.qnx.com/developers/docs/6.4.1/neutrino/prog/make_convent.html
Aleksandar
EXTRA_INCVPATH added to -I compiler option
EXTRA_LIBVPATH is added to -L linker option
see http://www.qnx.com/developers/docs/6.4.1/neutrino/prog/make_convent.html
On 18/08/10 09:44 AM, Sunil Keshava wrote:
> Hello,
> Thanks
> Sunil
> http://community.qnx.com/sf/go/post63393
Elena and Aleksandar, thank you for the useful information!
Sunil
