Forum Topic - gnet and glib: (1 Item)
gnet and glib
I am trying to compile a QNX c project with the use of gnet and glib. The project compiles in kdevelop but after
applying cflags. I am wondering if there is any options in QNX Momentics IDE where I can add the cflags. The result of
not adding the cflags in QNX is causing the IDE to not find those libraries. Currently when I try to build a project it
reports an error: No such file or directory : gnet, also the same for glib. I am sure that the libraries are installed
because kdevelop has no trouble finding them.
I would like to know if gnet and glib libraries from Linux can be used in QNX or is there some conversion need? Also if
they can be used how can I add cflags so that QNX can find those libraries.
Thank you for you help in advance.
JP.
