Forum Topic - pthread_cond_timedwait returns errorcode EBUSY: (1 Item)
I posted  by mistake the same bug under topc15348 in QNX4 Community Support - Forum, but we are using Qnx Momentics 6.4.
1 so I think here it is wrightly placed.
I have some applications, which return at call of pthread_cond_timedwait the errorcode 16 (EBUSY).
In the manual its written, that this errorcode is for this function not possible.
The case is, when I call pthread_cond_wait() instead of pthread_cond_timedwait() than everything is fine.
So I would think, the condition variable and mutex variable, would be passed wright.
And the third parameter (abstime) I exemined by call of pthread_cond_timewait looks well either.
Could anyone give me tip?
I suppose there is a problem with unlocking the passed mutex in the pthread_cond_timedwait() - procedure, but
unfortunately I can't debug into it.
I suppose the topc14006 is a similar problem. Maybe there is a problem in the mutex-handling of qnx?
here the code snipped:
static OS_ErrorCode os_waitForCondition(OS_Event* ev, OS_NanoSec durationTime)
   int err;
   struct timespec spec;
   OS_NanoSec targetTime;
   if (!ev)
      tPrintf(TRC_FAULT | TRC_COSA, "%s: Invalid parameter", __FUNCTION__);
       return OS_InvalidParam;
   pthread_mutex_lock((pthread_mutex_t*) &(ev->mutex));
   if (ev->signaled)
      if (!ev->manualReset)
       ev->signaled = OS_FALSE;
       pthread_mutex_unlock(&ev->mutex);
       return OS_Success;
   if (durationTime != OS_INFINITE)
      OS_ErrorCode r = os_getCurrentTime(&targetTime);
      if (r != OS_Success)
         return r;
      targetTime += durationTime;
      if(targetTime > 1000000000ULL)
    	  spec.tv_sec = /*(time_t)*/ (targetTime / 1000000000ULL);
      else
    	  spec.tv_sec = 0;
      spec.tv_nsec = (long) (targetTime % 1000000000ULL);
      err = pthread_cond_timedwait((pthread_cond_t *)&(ev->cond),  (pthread_mutex_t *)&(ev->mutex), (const struct timespec*)&spec)
   else
      err = pthread_cond_wait(&ev->cond, &ev->mutex);
   switch (err)
      case 0:
         pthread_mutex_unlock((pthread_mutex_t*) &ev->mutex);
         return OS_Success;//signaled!
      case ETIMEDOUT:
         return OS_Timeout;
      default:
         tError(TRC_FAULT | TRC_COSA, err, "%s", __FUNCTION__);
         break;
   return OS_Error;
I have found a solution to avoid this problem, but I think this is not a clean one. And furthermore I don't understand
it!
If I insert this
	   struct timespec sl;
	   sl.tv_sec = 0;
	   sl.tv_nsec = 1;
	   nanosleep(&sl, NULL); //1 nanosec verzögern
directly after the row with
then everything is fine.
With best regards
Ales Lacen
