"use pipe" option in application profiler fails with "cannot create pipe"
06/30/2010 8:13 AM
post58173
Hello everyone,
I'm currently profiling some QNX applications with function instrumentation using the Momentics IDE. So far I've been
successful using the option to create a ptrace file on the target and transfer it automatically with the "upload while
running" option in the application profiler dialog.
Since my ptrace file is getting large quickly, and I'm a bit limited on memory, I would prefer to avoid the creation of
the ptrace file on the target. I understand that this can be done using the "use pipe" option. However, when I try it, I
always get an error message: "Error starting profiler service: cannot create pipe".
The documentation says:
"Create a pipe file on the target machine instead of a regular trace file. To use this option, the pipe daemon must be
running on the target machine, and the file can only be created on the real filesystem (i.e. not /dev/shmem)."
I think I've done everything correctly:
1) I selected a target file name for the pipe within a "real" filesystem (which is read/write accessible)
2) pipe is running as root
3) qconn is running as root
My target is x86 with QNX 6.4.1. My Momentics version is 4.6.1.
Am I missing something?
Thanks a lot in advance!
Lorenz
