Forum Topic - threads disappear in QNX 6.3.2:
I have a process that runs many threads. One of the threads is created by a library it (dynamically) links to.
The process start running OK (pidin shows all threads) and it seems to run OK until some point of time where suddenly
some threads are not there. There are many threads that disappear (pidin does not show it) and, if it gives more
information to anyone, the thread created by the library it links to is gone too.
There are parts of the code that pthread_cancel() that threads, but I've added prints (write + fsync) and is not being
executed. So I *really* don't understand what could be happening to make the threads disappear.
Also, always the remaining threads are in "REPLY" state
Does this rings any bell to any of you guys ? What can make a thread *disappear* ?
Is there something (I don't really know) to configure that makes a null de-reference instead of SEGFAULT all the process
 only a thread or something like that ?
Or some suggestion how to debug further this problem ?
Thanks a lot,
Rodrigo
Re: threads disappear in QNX 6.3.2
Can you debug it? Put breakpoints on pthread_cancel, pthread_exit.
Rodrigo Campos wrote:
process only a thread or something like that ?
> Thanks a lot,
> Rodrigo
> http://community.qnx.com/sf/go/post56760
I don't have access to the machine right now.
But I'm quite sure pthread_cancel is not being called, since I've added prints (write + fsync) and when the problem
happens the prints are not shown.
Any other ideas ?
> > Hi,
> OK until some point of time where suddenly some threads are not there. There
> too.
> added prints (write + fsync) and is not being executed. So I *really* don't
> disappear* ?
> reference instead of SEGFAULT all the process only a thread or something like
> that ?
> > Thanks a lot,
> > Rodrigo
You can run kernel tracing. But you need "access" for this. And you
ignored my comment about pthread_exit
> Any other ideas ?
>>> Hi,
>> too.
>> disappear* ?
>> that ?
>>> Thanks a lot,
>>> Rodrigo
> http://community.qnx.com/sf/go/post56762
I will try to have access and try kernel tracing. By any chance do you have some "hello world" example I can try ? :)
Sorry, I'm not sure if I  understand what you mean with pthread_exit. I was not clear, but I'm not using pthread_exit in
 any place of the code, so it shouldn't be pthread_exit either.
Thanks a lot, really
Rodrigo
> prints (write + fsync) and when the problem happens the prints are not shown.
> > Any other ideas ?
> >>> Hi,
> a
> There
> more
> gone
> >> too.
> >> disappear* ?
> like
> >> that ?
> >>> Thanks a lot,
> >>> Rodrigo
I only know how to do it from IDE. You have to read user manual it is
better written there than I can do here.
in any place of the code, so it shouldn't be pthread_exit either.
> Rodrigo
>>> Any other ideas ?
>>>>> Hi,
>> a
>> There
>> more
>> gone
>>>> too.
>>>> disappear* ?
>> like
>>>> that ?
>>>>> Thanks a lot,
>>>>> Rodrigo
Ahh, thanks a lot anyway!
> not clear, but I'm not using pthread_exit in any place of the code, so it
> > Rodrigo
> shown.
> >>> Any other ideas ?
> >>>>> Hi,
> by
> >> a
> run
> >> There
> >> more
> >> gone
> >>>> too.
> don't
> >>>> disappear* ?
> de
> >>>> reference...
> until some point of time where suddenly some threads are not there. There are
> too.
> disappear* ?
> that ?
Could be something QNX-specific that cause threads on "reply" state to be still there after a segfault too ?
I'll try to make a test-case, but some confirmation would be really nice =)
Thanks a lot,
Rodrigo
