Forum Topic - Phindows - connection to remote host xxx terminated unexpectedly:
I am unable to create a phindows session to make target (arm - i.MX25)
From the target Naviagtor, I right click on the target and select "Launch remote Photon"
The Phindows windows appears (see screenshot) and it start connecting to the target, until suddenly the error
"The connection to remote host 192.168.7.199 terminated unexpectedly. You may be able to reconnect to Photon session /
dev/ph69658 and continue working."
appears.
I have my inet.d set up correctly for phrelay:
# Neutrino specific services
phrelay    stream tcp nowait root  /usr/bin/phrelay         phrelay -x
Also, the etc/services has the entry
phrelay 4868/tcp
I am able to create a telnet session, and have even tried first manual starting an instance of phrelay but this does not
 change the result.
Would appreciate any help
Marcel
Attachment: Image phindows_connect.jpg 106.73 KB
RE: Phindows - connection to remote host xxx terminated unexpectedly
It is possible that your target is not set up with all the required
components to start photon remotely. Can you connect to an already
running photon session, eg. /dev/photon? If so then your build file is
missing required items.
This topic has recently been documented, and I am attaching a draft of
the Phindows User Guide which contains this added information. Look at
the very end of the document for the chapter "Setting Up An Embedded
Target".
If for some reason you have difficulty getting the attachment, please
email me directly at mfeil@qnx.com.
Max
From: Marcel Meerstetter [mailto:community-noreply@qnx.com]
Sent: Friday, June 04, 2010 8:12 AM
To: momentics-community
Subject: Phindows - connection to remote host xxx terminated
unexpectedly
You may be able to reconnect to Photon session /dev/ph69658 and continue
working."
appears.
phrelay 4868/tcp
starting an instance of phrelay but this does not change the result.
Marcel
http://community.qnx.com/sf/go/post56039
Attachment: Text phindows_embedding.pdf 222.61 KB
