Download image via TFTP on 6.4.1 not working
04/21/2010 6:44 PM
post52341
So I am using 4.6 SDP (QNX 6.4.1) installed on Windows XP has host. The TFTP server is running in the view. I have
created my .ifs image file which resides at:
C:\ide-4.6-workspace\myproject\Images
directory
My x86 target board supports booting from Ethernet using Intel UNDI PXE-2.0 Bootrom that supports PXE/RPL TFTP boot.
In the IDE user guide under 'Downloading via TFTP' section in Chapter 6, it says "configure your target to request a
file recognized by the TFTP server". I am not sure how to configure my target device to do that. All my target device
does (when set to boot from ethernet) is to look up a DHCP server so that it can be assigned an IP address and then TFTP
server (on Host) usually provides the file (binary/image file) to be downloaded on the target device.
Here are my questions:
1. With my current target board capability can I use the TFTP download feature of the QNX IDE?
2. If yes, then what am I missing in my current setup?
3. Can I use serial port to transfer the image file in this case?
