04/08/2010 8:12 AM
post51321
I have a MIPSLE card running on QNX 6.4.1. The network driver is an io-net driver which is run using devn-shim (shim
layer) with io-pkt-v4. I do not see any problems while loading the network drivers and there are no problems with
assigning IP addresses as well.
But when I start qconn and try to see the folder structure on IDE, then I can only see the folders but not the files
present in the folders.
The same board was earlier running on 6.2.1 and it did not have any problem then. I am wondering if this is a network
driver issue.
Regards
Sunil
