Forum Topic - How to add a custom widget to Momentics in SDP 6.4.1?: (4 Items)
Hi, i haved installed the QNX 6.4.1 OS in a server, i figured out that the IDE does not come in, so i have it in Windows
 instead, but i need to develop a custom widget (wich by the way i still don't know much about how to do it). I have the
 code,  i have the .so library file i managed to get from an example in the documentation, and the PDF says something
about palete and template files in the PhAB, but i'm confused since the PhAB i'm using it's in Windows not in my target,
 where i compiled the widget.
I hope my problem it's clear. Any help will be a breath of fresh air.
Greetings.
Mario.
RE: How to add a custom widget to Momentics in SDP 6.4.1?
Hi Mario. To develop a custom widget using PhAB for Windows there are
two mandatory steps and a third optional step.
1) The custom widget must be built for the target you are using. This
will be the .so file that runs on the target.
2) PhAB palette and template files must be created to allow you to add
instances of your widget within PhAB. This step is documented. Note that
you will not see the contents of your widget within PhAB (just on the
target) unless you also perform step 3. But this will not affect your
ability to create instances of your custom widgets, specify resources,
add callbacks, etc.
3) This step is optional and a bit tricky. To also see the contents of
your custom widget in a WYSIWYG manner within PhAB, you need to build a
Windows dll of your custom widget. This is documented in the "Using PhAB
Under Microsoft Windows" appendix of the Photon Programmer's Guide. You
will need to install the Cygwin development environment and toolchain in
order to build your dll on the host. Depending on the version of cygwin
you use, the compile and link lines in the documentation may need to be
modified. You will need to experiment. That's the tricky part :)
Hope this helps,
Max
From: Mario Camargo [mailto:community-noreply@qnx.com]
Sent: Tuesday, February 23, 2010 1:12 PM
To: momentics-community
Subject: How to add a custom widget to Momentics in SDP 6.4.1?
the IDE does not come in, so i have it in Windows instead, but i need to
how to do it). I have the code,  i have the .so library file i managed
PhAB i'm using it's in Windows not in my target, where i compiled the
widget.
Greetings.
Mario.
http://community.qnx.com/sf/go/post48052
Re: How to add a custom widget to Momentics in SDP 6.4.1?
Ok, this it's definitely helpful, now at least i know what and where to look
to get this done.
Thank you very much. Im gonna try, and if it doesn't work hopefully i can
get a little more help here :)
Mario.
2010/2/23 Max Feil <community-noreply@qnx.com>
> add callbacks, etc.
> Hope this helps,
> Max
> widget.
> Greetings.
> Mario.
> http://community.qnx.com/sf/go/post48074
Hi, i've been trying to do the step 3, and for me it's a little more than tricky, i already have a hole in my head and a
 bunch of hair in the floor, and i still can't get the dll.
I have already tried with cygwin 1.7, 1.5 and a few modified headers that some nice guy sent me.
Anybody have at least a command i can use? Anything?
Thanks in advance.
Mario
