Trackers
Trackers
Forum Topic - vi and EXINIT: (4 Items)
vi and EXINIT
I use vi (aka elvis) as my primary editor under Neutrino, mostly because it is easily available on virtually every
platform I support (windows, linux, mac, etc.) I routinely define the EXINIT environment variable in order configure my
standard options, which happen to be:
  export EXINIT='set sw=2 ai'
As of 6.4.1, vi seems to no longer look at EXINIT, although the documentation still lists it. Is there a reason for the
change? Is it a bug or a feature? Is there some other way to initialize vi's configuration?
Re: vi and EXINIT
After digging through the source code (yeah source code!) I see that:
A) The functionality has changed. EXINIT is no longer used. Storing my initialization string in ~/.elvis/elvis.ini does
the trick.
B) The documentation in the utilities reference is now out of date. There is more current documentation in the source
tree under utils/e/elvis/doc
Re: vi and EXINIT
does the trick.
Off topic but are you (Norton Allen) still interested / involved
in perl on QNX.  Is so please drop me a line.
seanb@qnx.com
RE: vi and EXINIT
I've created a PR to get the docs updated.
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
> From: Norton Allen [mailto:community-noreply@qnx.com]
> Sent: Thursday, October 29, 2009 2:41 PM
> To: momentics-community
> Subject: Re: vi and EXINIT
> Storing my initialization string in ~/.elvis/elvis.ini does the trick.
> date. There is more current documentation in the source tree
> http://community.qnx.com/sf/go/post41007
