Forum Topic - Equivalent to IntContext()?: (3 Items)
I'm sharing some common code with an interrupt and a thread.
While in the interrupt, I'd like to avoid the kernel calls.
What's the best way to determine whether or not I'm currently executing in an ISR?  In VxWorks intContext() call was
available.
I'm running 6.3.2.
Cheers,
Rob
Re: Equivalent to IntContext()?
What processor target is this?
On most processors, the cpupage (accessed via _cpupage_ptr) has some status
bits set by the kernel on interrupt handling, but x86 is different:
#if defined(__X86__)
     #include <x86/inline.h>
     #define in_interrupt()      ((_cs() & 0x3) == 0)
#else
     #include <sys/syspage.h>
     #define in_interrupt()      (_cpupage_ptr->state & 0x3)
#endif
	Sunil.
Rob Maher wrote:
available.
> I'm running 6.3.2.
> Cheers,
> Rob
> http://community.qnx.com/sf/go/post39605
Just what I need!  Thank you Sunil!!
